I was follow step by step, re-follow step by step but allways error for compile full android or u-boot only. i follow this tutorial http://www.udoo.org/docs-neo/Advanced_Topics/Compile_Android_From_Source.html Hallo udoo admin, could you test your tutorial? I attached file. My System: Host = Core i7, Windows 7 64bit Guest = Ubuntu 16.04 64bit, RAM 3GB, CPU Core 2, Swap 2GB, HD 100GB
I've tried to follow the tutorial above, but always just errors like the file log.error I included above. What else ?
I had also to do this to generate that static library: https://gerrit.omnirom.org/#/c/15028/1/lib/Android.mk That is: add to extemal/lz4/lib/android.mk this lines: include $(CLEAR_VARS) LOCAL_MODULE := liblz4-static LOCAL_SRC_FILES := $(liblz4_src_files) LOCAL_MODULE_TAGS := optional include $(BUILD_STATIC_LIBRARY) Good luck
