How to connect Curie to external PC
Discussion in 'UDOO X86' started by Opilki_Inside, Jul 21, 2017.
  1. Opilki_Inside
    Opilki_Inside New Member
    Jul 12, 2017
    Hey there,
    I've installed Android on x86, now I want to connect Curie to external PC and upload some code. I could not find and tutorial describing how to connect Curie to external PC on UDOO x86.
    Please help.
  2. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    I don't think you can do that easily. Curie is internally connected to UDOO X86 via internal USB and that can't be changed.
    You are supposed to program Curie from UDOO X86 (but I have no idea how to do that from Android).
  3. Jetguy
    Jetguy Member
    Mar 28, 2017
    65
    60
    Wilson, LDighera and Markus Laire like this.
  4. Wilson
    Wilson New Member
    May 5, 2017
    25
    The USB port is connected directly to the main processor, so you cannot program via Arduino IDE from external computer using USB.
    It is possible to program it externally via the JTAG port though. I am not sure of the process, if any, to perform JTAG programming via Arduino IDE. If you have a compatible JTAG programmer, there are instructions for doing it via the Intel Curie Open Software Developer Kit. See https://software.intel.com/en-us/node/675000 and https://www.zephyrproject.org/doc/1.2.0/board/arduino_101.html#connecting-jtag-to-arduino-101
    If you're feeling fancy, Arduino 101 like boards are compatible with the free Intel System Studio for Microcontrollers. It is an IDE extension for Eclipse and can perform programming and debugging of the Curie chip via JTAG. https://software.intel.com/en-us/intel-system-studio-microcontrollers
    NOTE: I have not attempted to do JTAG programming with the Arduino 101 compatible side of the UDOO x86 yet, so I cannot speak to if it works. I haven't had a working JTAG programmer in a while, but I have one coming to me in the mail right now.
    LDighera likes this.
  5. waltervl
    Next to the Arduino web IDE solution you could install a second OS (ie Ubuntu) and use the Arduino IDE on that. After uploading the compiled sketch you can reboot into Android.
  6. Darknain
    Darknain New Member
    Mar 7, 2018
    24
    According to this :
    https://www.udoo.org/docs-x86/Arduino_101_(Intel_Curie)/Getting_Started_with_Arduino_101.html
    It's possible to programm directly on the intel curie with Arduino IDE.
    I would like the Arduino 101 to get external data using I2C or SPI and send them to the Intel N3710 but I don't know how I can do that.
    I am planning on installing windows on the udoo board but I don't know how to do the communication between the 2 processors.
  7. waltervl
    You can use the standard available USB Serial device to communicate from N3710 to Curie and viceversa. Udoo X86 is the same as using a PC and a Curie connected with USB cable. The USB connection is also already embedded. From the same documentation page:
