How to create an image from my Udoo's OS?
Discussion in 'General Discussion' started by alexandros301, Jan 20, 2015.
  1. alexandros301
    alexandros301 Member
    Mar 22, 2014
    40
    I'm using Udoo with Debian for Udoo and I'd like to create an image with everything I have installed etc, in order to use it with more Udoos, so that I don't have to install everything from scratch. How can I achieve that? Never made an image before..
  2. schnabelvieh
    schnabelvieh New Member
    Jan 18, 2015
    Hey,
    you might want to use dd ......
    1) Get your sd-card out of the udoo and use a usb-sd-card reader
    2) Use dmesg to figure out which /dev/sd{sd-card} was created after you've plugged in your reader
    3) dd if=/dev/sd{sd-card} of=/path/to/my_image bs=1M
    NOTE: You need to be carefull with dd. Using something like
    dd if=/path/to/my_image of=/dev/sd{WRONG}
    is going to kill your linux-installation, when you want to duplicate your image on a fresh sd-card
    have fun,
    schnabelvieh
  3. alexandros301
    Mar 22, 2014
    40
    damn, didn't cross my mind it's the same process as installing an image to an SD card from your computer...
    I guess I can give the image any name I want...like in your example it my_image, plus I should (or not?) give it the .img extension?
    Lastly, if I want to burn that image to a new SD card, all I need to do is this
    dd if=/path/to/my_image.img of=/dev/sd_card bs=1m
    right? (I usually use 1m at the end, not 1M - I'm on OS X)
    Cheers
  4. delba
    1,064
