How-To: Fan adapter cable
Discussion in 'UDOO X86' started by ImLagging, May 16, 2017.
  1. Robert Pearson
    Robert Pearson Member
    36
    15
    Looks beautiful! Has anyone turned the heatsink 90 or 270 degrees yet, for more airflow?
    Robert
  2. wsian
    wsian New Member
    Apr 2, 2017
    18
    Finally, with firmware 1.03, you can now set the fan to be permanently on.
    :) Thanks to Udoo Team.
    thE_29, ektor5 and Fuzzyroll like this.
  3. thE_29
    thE_29 Member
    May 2, 2017
    34
  4. cagiva
    cagiva UDOOer
    Aug 28, 2017
    15
    @ThomasOu, your fan only has two wires so do you leave the FAN_TACHO_IN (Pin 3) disconnected?
  5. ThomasOu
    ThomasOu Member
    Apr 28, 2016
    33
    26
    Firstly, my fan doesn't have a third pin, which used to report fan speed to board. Secondly I don't think leaving the FAN_TACHO_IN (Pin 3) will cause trouble, and it is truth also. It works well under 50% and 100% speed.
  6. cagiva
    cagiva UDOOer
    Aug 28, 2017
    15
    I'm not planning to use the Arduino pinout headers so this solution worked best for me. Thanks!
  7. Clément
    Clément New Member
    Aug 19, 2017
  8. Sjonno
    Sjonno New Member
    Apr 24, 2017
  9. Clément
    Clément New Member
    Aug 19, 2017
    @Sjonno Could you post a picture of the pins you used ? I was thinking of using a lower voltage as well
  10. Sjonno
    Sjonno New Member
    Apr 24, 2017
    Here you go. The GPIO on the UDOO are labeled, so pretty easy to connect.
    I made the fan connector shorter today to make it look better.
    IMG_20171112_114124553.jpg IMG_20171112_114139008.jpg IMG_20171112_114257571.jpg
  11. papman
    papman New Member
    Apr 29, 2016
    Can you tell the name of the parts?
  12. cagiva
    cagiva UDOOer
    Aug 28, 2017
    15
    papman likes this.
  13. Eponymous
    Eponymous New Member
    May 12, 2017
    Though I still need to adjust the set temperature in the BIOS (I normally run headless and my TV seems to be incompatible with viewing the BIOS), this fan appears to be working well (spins up for some sort of self-test on boot) and is essentially silent. As you can see from the pictures (1 and 2), I made my own cable adapter for it, but re-reading the listing, it appears as though I could have specified the correct plug and gotten a turn-key solution directly from the seller.
  14. Jorge
    Jorge New Member
    Oct 21, 2017
    15
    What is the correct plug for udoo x86?
    [​IMG]
    [​IMG]
    Thanks a lot
  15. ImLagging
    ImLagging Member
    May 9, 2017
    73
    28
    I’m almost positive that it’s C2, but I don’t have one in front of me at the moment to compare. I’ll try to look tonight when I’m able to. Or maybe someone else will be able to confirm before then.
  16. waltervl
  17. ImLagging
    ImLagging Member
    May 9, 2017
    73
    28
    Looking at the pictures, I believe what you linked to is what the C2 is in his post. Without knowing the dimensions, I can’t say for sure, but it has the right shape (it doesn’t need to be 100%).
  18. Eponymous
    May 12, 2017
    When I made the post, I was thinking of C2, but closely comparing the images with some spare connectors I have and at the link from waltervl, I don't think it's quite a match. The left C2 image shows a solid "ridge" along one side of the connector. The equivalent view at the link (and the known to be good spare connectors I have) show just a tang.
  19. ImLagging
    ImLagging Member
    May 9, 2017
    73
    28
    I believe that ridge is to help prevent inserting the connector the wrong way. I’ll have to double check o
    When I’m home, but I’m pretty sure that there’s a notch on the UDOO to allow the ridge to fit into. What I bought looks similar to what waltervl posted. However, I can’t find a good picture of the connector on the board itself.
  20. Eponymous
    May 12, 2017
    ImLagging is right, there is a feature in the connector that I think would align with the ridge. Here's a picture I took
    [​IMG]
    I believe I have photographed the relevant side of the connector, but it's difficult to be sure. The complicated shape of the slot makes me think it's actually for the tang (i.e. not C2), but the ridge may fit, it's hard to say
