How to make an iso backup image of micro sd card on udoo ?
Discussion in 'UDOO X86' started by wolfy, Oct 26, 2017.
  1. wolfy
    wolfy New Member
    Oct 26, 2017
    Hello,
    Like on Raspberry pi 3, I would like to make a backup image of ubuntu that I have installed on a micro sd card on a udoo x86 single board.
    The Micro sd card works, it boots on UEFI mode.
    However, when I have to switch the micro sd card with another on an other udoo x86, it doesn't work.
    Likewise, when I want to load the image.iso on an other udoo card, it doesn't work.
    I can boot with : [ESCAPE] and then boot from file and then I explore the sd card. But the boot manager doesn't recognize the micro sd card as an UEFI device (the only way to boot).
    How to make some switchable backup iso on udoo x86 which can boot whatever is the card ?
  2. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    UEFI saves some boot-settings internally and you might need to save/update/restore those for other card to boot.
    I would recommend using legacy booting instead of UEFI if possible, since it is much simpler.
  3. wolfy
    wolfy New Member
    Oct 26, 2017
    I can't install Ubuntu on micro sd card with legacy mode with udoo x86 :-(
    And you ? Are you able to do it ?
  4. Markus Laire
    Mar 9, 2017
    225
    92
    I don't remember if I've tried that, but it should work.
  5. wolfy
    wolfy New Member
    Oct 26, 2017
    it seems to me that it freezes or it crashes towards the end of the installation with ubuntu live usb.
