How to program udoo using Python?
Discussion in 'UDOO NEO' started by Reem AlJunaid, Feb 19, 2017.
Tags:
  1. Reem AlJunaid
    Reem AlJunaid New Member
    Feb 19, 2017
    I have a bioloid robot and I want to control it using UDOO but with Python (I should program it by Python, It's recommended)
    I am new in this field, I never programmed robot using any board (UDOO, Arduino or Raspberry Pi)
    What are the steps I should follow at the beginning?
    Do I need to install any SDK for Python in the UDOO board?
    Could you help me in this?
  2. Andrea Rovai
    Hi Reem,
    if this is your first experience you should take a look around on the Internet and look for some tutorials.
    I especially suggest you to take a look at hackster.io, where you can find many UDOO projects to get inspired.
    EDIT: udoo.hackster.io
  3. waltervl
    Python is preinstalled so you have nothing to install. I personally like the Geany editor (also preinstalled) because of the python interpretation and the ability to run the python scripts from the UI.
    Extra libraries you need can be installed by the standard command line tools. (apt-get -install, pip etc)
    There are also some libraries specially made for the Neo: http://www.udoo.org/docs-neo/UDOO_NEO_made_by_the_Community/Python.html
    The decision you have to make is how to control your robot: From the Arduino side or Linux side (the Neo is a combination of a Raspberry Pi-ish and an Arduino Uno-ish). You cannot use Python scripts for the Raspberry Pi GPIO directly on the Udoo Neo, they will not work!
    For an introduction you can also look into my two How-To (see links in my signature) but are not exactly about controlling robots.
    Reem AlJunaid likes this.
  4. Reem AlJunaid
    Feb 19, 2017
    Thank you too much, you really helped me a lot with this !
    waltervl and Andrea Rovai like this.
  5. Reem AlJunaid
    Feb 19, 2017
    Thank you Andrea
    Andrea Rovai likes this.
  6. Andrea Rovai
    You're welcome! Also, welcome in the community!
