How to rotate HDMI?
Discussion in 'Accessories' started by mushketer888, Feb 12, 2015.
  1. mushketer888
    mushketer888 New Member
    Jan 13, 2015
    20
    Hello all...
    I have question how to rotate HDMI?
    i have lcd panel over hdmi
    and i need to rotate it upside down
    i will say that xrandr cant do anything!
    i tried to edit xorg.conf Device section, for example:
    Section "Device"
            Identifier      "i.MX Accelerated Framebuffer Device"
            Driver "vivante"
            Option          "fbdev"         "/dev/fb0"
            Option          "vivante_fbdev" "/dev/fb0"
            Option          "HWcursor"      "false"
            Option          "Rotate"        "UD"
    EndSection
    It doesnt change anything either...
    How can i rotate 180 degrees hdmi output?
  2. Gavin Koh
    Gavin Koh New Member
    Oct 12, 2016
    With xrandr, first run the following:
    xrandr -q --verbose
    You should see something like:
    Screen 0: minimum 240 x 240, current 1920 x 1080, maximum 8192 x 8192
    DISP3 BG connected 1920x1080+0+0 (0x40) normal (normal left inverted right x axis yaxis) 0mm x 0mm...
    Next, use:
    xrandr --output "DISP3 BG" --rotate normal/inverted/left/right
    Girish and Andrea Rovai like this.
  3. Girish
    Girish New Member
    Nov 27, 2018
    Thanks Gavin. That works :)
