HowTo: Fix Ubuntu 17.04 DNS not working
Discussion in 'UDOO X86' started by Maurice, May 11, 2017.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    Got one of the two boards up and running, except for DNS. It has a wired connection and it gets the correct DNS configuration (8.8.8.8, 8.8.4.4) . A ping with an IP address is ok, but not with a hostname.
    After some searching this seems to be an issue in Ubuntu, which has been solved, but needs an update. Yes, a true catch-22. You can't update Ubuntu if your DNS isn't working, and you can't get DNS working without an update.
    In order to solve this I added the IP addresses that sudo apt-get update showed it could not resolve. In my case it was security.ubuntu.com and nl.archive.ubuntu.com. On a different machine I looked up their IP-addresses and added them into /etc/hosts.
    After that I performed the several upgrade tasks (apt-get, Ubuntu Software,...) and after a reboot the problem seems to be resolved.
    [Edit: Note that this is a Ubuntu problem, not a UDOO problem]
    Markus Laire likes this.
