I can't find /dev/ttyMCC and pwm0~6
Discussion in 'UDOO NEO' started by yangbeng, Apr 12, 2016.
  1. yangbeng
    yangbeng New Member
    Apr 7, 2016
    i did sudo apt-get update and sudo apt-get upgrade
    but i can't find ttyMCC
    and one more i want PWM1~6 but i did cd /sys/class/pwm and ls
    i found just pwmchip0 pwmchip1 pwmchip2 i want 3 more please help me
    Did you switch off the M4 (Arduino)? Because then there is no ttyMCC.
    If you want to use more than 2 PWM pins in Linux you have to switch off the M4 (Arduino) because the other 6 PWM are reserved for the Arduino side.
    You have the choice to use the 6 PWM from Arduino and use the Arduino IDE to use them. Or switch off M4 and do all kind of complex Linux stuff to access them from the Linux side. You have to rebuild the device tree yourself.
    So my advice for you would be to use the Arduino PWM.
    Francesco and yangbeng like this.
  3. yangbeng
    yangbeng New Member
    Apr 7, 2016
    thank you but i want use Linux terminal and use more pwm
    I do your advice in switch off Arduino and i enter /opt/dtweb/public/boards/neo/board.js and set up more pwm in board.js
    than device tree is wrong pin number block is disappear.
    and one more. i control pwm0 but signal appear in pin30(pwm5/gpio18)
  4. yangbeng
    yangbeng New Member
    Apr 7, 2016
    and enable arduino but i did not find /dev/ttyMCC
  5. waltervl
  6. waltervl
    If you use the Arduino IDE on the Neo can you program the Arduino side? It also uses this serial device.
    Perhaps you have to refresh your linux image on the SD card to be sure older changes are not hampering you.
