Has anyone been able to find a compatible connector for the camera or i2c connectors on the udoo neo? I would like to make a cable for mine Sent from my E6782 using Tapatalk
Thank you jas-mx for the quick reply. I saw your post shortly after submitting mine and am looking for those connectors now. You had a comment that you need specific cameras for your post. Is that to work with the udoo neo in general, or were those specific cameras for your project. Sent from my E6782 using Tapatalk
If you want to use the camera connector then you need a camera that supports NTSC (720x480) or PAL (720x576) resolutions. As discussed in the other thread there are limitations on using a camera with NEO (either through the connector or through USB) for example you can't encode/decode the camera output to mpeg/h264. So a camera (NTSC/PAL) used through the connector is mainly useful as an output to screen. A USB camera is only useful for streaming or capturing single images to a file.
