Infra red port & Linux
Discussion in 'UDOO X86' started by Thierry, Oct 4, 2017.
  1. Thierry
    Thierry New Member
    May 15, 2017
    Hello
    I was wondering if there is some news about IR port ?
    I've saw in bios/UFI an option to use IR port in order to wake up (?) Udoo, but nothing in order to use this port a serial port !
    Does the team work on a solution ?
    The IR port use the STM32F100 to communicate with the Intel CPU and i don't know how use the STM32F100 to access to IR port ?
    I use Linux... and i like to use this port in my /dev/tty???
    Thank's
    Thierry
  2. ccs_hello
    536
    194
    Thierry,
    That IR receiver device is a "consumer IR" device, not a serial port device.
    That C-IR receiver is being front-end processed by STM32 microcontroller, then feed thru
    Intel x86's SM-bus to the Intel CPU.
    Check the CEC Framework thread to understand how it is supposed to be used.
    https://www.udoo.org/forum/threads/kodi-ir-logitech.7418/#post-30207
    ccs_hello
  3. Thierry
    Thierry New Member
    May 15, 2017
    Thank's...
    I have ever read this about CEC, but not up to the end ;-)
    It's right that it not seem to be serial port : when you want to pilot Kodi with this, you think that it will be hard to do this if it's not a serial port... but this article said it would be possible : i'm going to try it...
    Does someone here has ever do that ? pilot Kodi by using IR port ?
