Install error when installing Ubuntu 17.04
Discussion in 'UDOO X86' started by Lyle, Aug 15, 2017.
  1. Lyle
    Lyle New Member
    Aug 15, 2017
    I created a bootable SD drive via
    1. First using dd (this is how I've always created bootable SD cards)
    sudo dd if=ubuntu-17.04-desktop-amd64.iso of=/dev/sda bs=8M status=progress && sync
    2. Then because I was getting a warning in gparted - which looks related EFI - I recreated via
    sudo sgdisk --zap-all /dev/sda
    sudo sgdisk --new=1:0:0 --typecode=1:ef00 /dev/sda
    sudo mkfs.vfat -F32 /dev/sda1
    sudo fdisk -l /dev/sda
    sudo mount -t vfat /dev/sda1 /mn
    sudo 7z x ubuntu-17.04-desktop-amd64.iso -o/mnt/
    sync
    The gparted warning is gone, but both methods result with:
    1. From the boot manager from the initial boot menu, I boot using:
    EFI SD/MMC Card (SL64G) (I get unbootable device error if I choose the hard disk SL64G entry)
    2. I see the following two lines
    platform wdat_wdt: failed to claim resource 4
    acpi: watchdog: Device creation failed: -16
    3. it reboots and I go back to step 2 over and over and over again.
    If anyone has any idea's I would be grateful.
    Thanks
    What UEFI firmware version are you on?
    v1.0.1 has USB/SD card issues so you have to be on at least v1.0.2.
    And what if you are not stubborn and just follow the general instructions regarding Ubuntu installation?
  3. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I installed Ubuntu by booting it into the demo mode, used gparted to remove the QA partition and then started the installation. I've installed multiple X86s by now with Ubuntu 17.04.
  4. franksey
    franksey New Member
    Aug 11, 2017
    Definitely upgrade BIOS firmware. I'm on 1.03 and using Ubuntu 17.04 booting from an SD card.
