Is it possible to implement a tcp server with arduino?
Discussion in 'Arduino IDE' started by simcode, Dec 2, 2013.
  1. simcode
    simcode New Member
    Dec 2, 2013
    source that has been implemented in ethernetshield exists, but this I do not behave.
    What shall I do?
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    You mean plug in an Arduino Due ethernet shield to the SAM3X8E, and load/run the corresponding networking library to provide a full tcp/ip stack, then load on top of that a lightweight server to serve requests?
    sure, by why would you want to?
    you have a full fat i.MX6 with all the networking already done on the same board.
  3. simcode
    simcode New Member
    Dec 2, 2013
    I have to say, it is one that was want to know how you can arduino to a server role in arduino in udoo board.
    How to implement an tcp server on arduino?
  4. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Hi all,
    I'm adding a question: how is it possible to reuse arduino sketch based on ethernet shield without using it?
    Can i.MX6 simulate an ethernet shield? Any code sample?
    Thanks
  5. Lifeboat_Jim
    Sep 16, 2013
    399
    You mean a 'loopback'? Ought to be available, most network stacks do that in logical rather than physical layers.
    Google/text search the library you have for that phrase.
    localhost and 127.0.0.1 would work too of course.
  6. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    im a bit confused by the various questions, and assuming languange differences..
    first off,
    Can you use the arduino as a TCP Server, Yes, but since the Due cant directly access the wifi on the i.MX6 side, you would need a shield
    The point made by Lifeboat_Jim, though is why bother... the i.MX6 running linux can run a 'very' powerful TCP Server with wired and wireless networking with very little setup. it can then pass info to and from the SAM3X8/Due chip as needed. this i generally the easiest way from what i have seen so far.
    Freedomatic, from what i recall (and i may be a bit rusty on the details) i dont think its currently possible for the i.MX6 to provide the SAM3X8 access to the wireless card to be able to emulate or simulate a functional wireless shield.. maybe i misunderstood the question?
  7. simcode
    simcode New Member
    Dec 2, 2013
    thank you.
    Any code sample?
  8. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    @DracoLiasa I'd like to use the board ethernet connection instead to add a specific shield.
  9. simcode
    simcode New Member
    Dec 2, 2013
    i mean that need arduino sketch code example..
  10. Lifeboat_Jim
    Sep 16, 2013
    399
    Can't be done. Ethernet port is physically connected to the i.MX6.
  11. Bulbox
    Bulbox New Member
    Feb 18, 2014
    10
    Hi guy's, i have tried to connect ethernet shield to arduino board implemented in udoo QUAD ..but it don't work, because the arduino board implemented in UDOO QUAD haven't ICSP pinout , These pins allow communication from ethernet shield and arduino!!!!
    it is possible to connect in some other way the ethernet shield for arduino to UDOO QUAD ARDUINO 2 board???
  12. Bulbox
    Bulbox New Member
    Feb 18, 2014
    10
    SOLVED!!!!!!!!!!! now i post how!
  13. Bulbox
    Bulbox New Member
    Feb 18, 2014
    10
    connect ICSP pin's of ethernet shield to UDOO :
    [​IMG]
    [​IMG]
    1 (shield) -- MISO -- 1 (UDOO)
    3 (shield) -- SOCK -- 3 (UDOO)
    4 (shield) -- MOSI -- 2 (UDOO)
  14. theravech
    theravech New Member
    Feb 4, 2014
    And the pin 2 of the shield connect to pin4 of udoo?
  15. zisosak
    zisosak New Member
    Mar 19, 2015
    14
    What do mean with that waht is the pin number from the shield and the pin numeber on udoo;
  16. RickyTerzis
    RickyTerzis New Member
    Aug 2, 2017
    Hi...i am a new user here. As per my knowledge Due cant directly access the wifi on the i.MX6 side, you would need a shield.The point made by Lifeboat_Jim, though is why bother, the i.MX6 running linux can run a very powerful TCP Server with wired and wireless networking with very little setup. it can then pass info to and from the SAM3X8/Due chip as needed.
    pcb manufacturing
