J18 kills output on Serial Port on Quad Board
Discussion in 'Troubleshooting' started by moorsb, Mar 13, 2014.
  1. moorsb
    moorsb New Member
    Feb 20, 2014
    36
    I found this out the hard way. I was trying to setup booting of Sata SSD but could not see anything on the pc terminal
    I found the system booted better without the jumper on J18 so I had removed it early on. Once I had my pc setup to monitor the CN6 port I was not getting any data. I debugged everything else then I decided to put the jumper back on and see if anything changed. It did
  2. Oromit
    Oromit New Member
    Mar 14, 2014
    It doesn't kill it, removing it connects the port to the Arduino Chip, so it can be flashed via USB, as stated in the documentation.
  3. andcmp
    andcmp New Member
    161
    Yes, Oromit is right. ;)
    [​IMG]
  4. moorsb
    moorsb New Member
    Feb 20, 2014
    36
    What I am saying is I got no data from Uboot with the Jumper off. So the Serial Port was not connected.
  5. Oromit
    Oromit New Member
    Mar 14, 2014
    And two people just explained you why.
  6. moorsb
    moorsb New Member
    Feb 20, 2014
    36
    I understand why, I was just letting other people who may have done the same thing know about it.
