Kernel 4.0.8 from Igor Pečovnik ?
Discussion in 'Kernels' started by alfwro13, Jul 27, 2015.
  1. alfwro13
    alfwro13 New Member
    Dec 29, 2014
  2. mocho
    mocho New Member
    Mar 14, 2015
    I am using one of its debian images with kernel 3.18 long time ago. I think its the best images avalailable but it lacks video decoding hardware acceleration. I tryed last ubuntu image but could not start desktop enviorment because of some seg fault
  3. patrykk
    patrykk Member
    Dec 10, 2014
    52
    Igor use kernel from my repo : https://github.com/patrykk/linux-udoo.
    This kernel support newest vivante drivers and you have to have support for EGL, OpenGL, VPU. You could run apps like:
    • XBMC (preloaded framebuffer libs)
    • gstream
    • chromium with EGL and flash 12.x
    • neverball
    • stellarium
    • celestia
    It support everything like 3.14 from uduoobuntoo2 long time.
    If you have some problem please supply some logs. We will try resolve a problem.
    best regards,
  4. dcop
    dcop New Member
    Aug 17, 2014
    Since I'm reading this topic and I have some trouble cross-compiling your kernel, here's my output:
    http://pastebin.com/WBkvWTmf
    I'm cross compiling following udoo docs, I even copied the udoo_defconfig:
    1) make ARCH=arm udoo_defconfig (yes, named it this way)
    2) make ARCH=arm menuconfig
    3) make -j4 CROSS_COMPILE=../arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi- uImage LOADADDR=0x10008000 modules (yes, binary is there)
    This is my first attempt to compile a newer kernel, always used the old 3.0.
    Thanks for your time!
  5. cyrilf
    cyrilf Active Member
    Feb 19, 2015
    168
    47
  6. patrykk
    patrykk Member
    Dec 10, 2014
    52
  7. dcop
    dcop New Member
    Aug 17, 2014
    Still the same problem for me, even with the newest kernel from UDOO I've got the same error. Guess I'm really missing something when cross compiling.
  8. cyrilf
    Feb 19, 2015
    168
    47
    Xykon, dcop and patrykk like this.
