Hello, I am having some issue with the cross compiler, i am following this guide (http://udoo.org/download/files/Document ... 0_2013.pdf) when i go to start the build its throwing an error Code: root@VOID-LINUX:/home/kieran/kernel# make -j4 CROSS_COMPILE=../arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi- ARCH=arm uImage modules > compile.log make: ../arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-gcc: Command not found make: execvp: /home/kieran/kernel/scripts/setsecoversion: Permission denied /bin/sh: 1: ../arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-gcc: not found make[2]: *** [scripts/mod/empty.o] Error 127 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [scripts/mod] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [scripts] Error 2 make: *** Waiting for unfinished jobs.... root@VOID-LINUX:/home/kieran/kernel# Also when i go to run that exe directly it still is saying command not found even though that files exists Code: root@VOID-LINUX:/home/kieran/arm-fsl-linux-gnueabi/bin# arm-fsl-linux-gnueabi-gcc arm-fsl-linux-gnueabi-gcc: command not found root@VOID-LINUX:/home/kieran/arm-fsl-linux-gnueabi/bin# Has anybody else successfully built the kernel with the cross compiler yet? Any help would be greatly appreciated Code: kieran@VOID-LINUX:~$ uname -a Linux VOID-LINUX 3.8.0-23-generic #34-Ubuntu SMP Wed May 29 20:22:58 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
Your problem is quite difficult! You installed the crosscompiler but you can't execute it! Try this: apt-get install ia32-libs And then try to execute again the crosscompilation! ;-)
Ah! Thank you! All working well now! (All this for CIFS ) Code: Linux udoo 3.0.35-ga93e2dc #1 SMP PREEMPT Mon Oct 28 21:17:43 GMT 2013 armv7l GNU/Linux
I'm stuck at the third step: Code: ubuntu@imx6-qsdl:~/kernel$ dir -a . .. uImage ubuntu@imx6-qsdl:~/kernel$ sudo make ARCH=arm UDOO_deconfig make: *** No rule to make target `UDOO_deconfig'. Stop. I'm running a quad that is booting from a sata drive. Any ideas that would help a complete noob?
make ARCH=arm UDOO_defconfig You had a typo. sudo should not be needed for a kernel compile. Wait, are you even in a kernel source directory? Are you compiling on the board, or cross-compiling?
Forget cross-compiling, use the Linaro 11.10 image provided as your compiling environment. It greately simplifies many things and get's rid of the errors you are seeing. I have compiled a kernel several times under 12.04, the problem is I can't get ANY custom kernel to boot. I wish that the Udoo team would stick with the GPL license and make the U-Boot source available and make the kernel .config available so that we can help them make the Udoo platform better and on a supported OS.
i hav this error . help me out user@user-OptiPlex-7010:~/kernel_imx$ export ARCH=arm user@user-OptiPlex-7010:~/kernel_imx$ export CROSS_COMPILE=/home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi- user@user-OptiPlex-7010:~/kernel_imx make wandboard_defconfig # # configuration written to .config # user@user-OptiPlex-7010:~/kernel_imx$ make -j6 make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc: Command not found scripts/kconfig/conf --silentoldconfig Kconfig make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h CC scripts/mod/empty.o /bin/sh: 1: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc: not found make[2]: *** [scripts/mod/empty.o] Error 127 make[1]: *** [scripts/mod] Error 2 Code: make: *** [scripts] Error 2 make: *** Waiting for unfinished jobs....
wr i hav to include -gcc? can u plz be specific i m struck in this i tried export CROSS_COMPILE=/home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc also .. i hav the same error: make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc-gcc: Command not found scripts/kconfig/conf --silentoldconfig Kconfig make: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc-gcc: Command not found
You don't have Code: /home/user/wandboard-4.4.2_1-presource/wand-4.4.2_1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-gcc-gc I don't know what is wrong. Maybe you set wrong path in CROSS_COMPILE?
