Laser cut snap together case - Free
Discussion in 'Cases' started by ajhalls, Feb 20, 2014.
  1. ajhalls
    ajhalls New Member
    Oct 13, 2013
    This is a double post, I didn't see the subforum for cases earlier, sorry.
    Snap together case for a Udoo Quad. I left enough room on top for 1 module, if you need more room you just need to extend the sides. If you make improvements, I would love to get a copy - my email is in the artwork.
    You are welcome to use it for personal use but if you are going to start up a business selling them, you ought to talk to me or draw your own :)
    Uses a piece of 1/4" acrylic about 7" X 16".
    Universal EPS File:
    http://www.coursesaver.com/alan/udoo/UdooCase.eps
    Corel Draw File:
    http://www.coursesaver.com/alan/udoo/UdooCase.cdr
    Completed:
    [​IMG]
  2. mkopack
    mkopack Member
    451
    Very nice!
    Can I make a suggestion? - Make a modified version that has an additional "layer" so we can put a HD underneath... Should just need to extend the sides to be "taller" and then add a 3rd tray with the mounting holes for the HD, and change the tray for the Udoo to have pass-through holes for the HD power+data cables to route through...
  3. Maxr96
    Maxr96 New Member
    Jul 4, 2014
    Good job, but can I give an advice? Put an extra layer to place the HDD, and you can also place a fan.
  4. hiro.kaneko
    hiro.kaneko New Member
    Jul 24, 2014
    12
    Thank you for your data!
    I made a UDOOcase using your data in Japan, very nice.
    [​IMG]
    However, I hope to improve your data about the following.
    When I install Quad, some screw holes of the corner of the board are not effective.
    I hope for the data with screw holes fitting Quad.
