LED controlled by ARM m4
Discussion in 'UDOO NEO' started by tonyuan, Jul 19, 2016.
  1. tonyuan
    tonyuan New Member
    May 20, 2016
    Hi
    I am running MQX on M4 core. And I try to make the LED controlled by M4 blinking but failed.
    I have seen from the UDOO NEO doc, and it has the following hints
    "Just control the digital pin 13 to get information on code running on M4 sketch."
    I do not quite understand what is digital pin 13. And according to the context, it seems the digital pin 13 is related to Arduino.
    And I have found from "Use more digital pins on M4", the number 13 Arduino pins has the following definition. So from the definition, i can found related registers of IOMUX and GPIO. If i want to make the LED blink, should I operate on the related IOMUX and GPIO registers?
    #define ARD_DIO13 (LWGPIO_PORT4 | LWGPIO_PIN6)
    #define ARD_DIO13_MUX_GPIO (LWGPIO_MUX_PORT4_PIN6_GPIO)
  2. Andrea Rovai
    You don't need IOMUX or GPIO registers through Arduino. Btw, everything - included what is the digital pin 13 - is in the documentation.
    To blink LED 13 in M4 you just need to use the Arduino IDE.
