limited touch area on 7" LVDS
Discussion in 'Android' started by objectr, Jun 25, 2014.
  1. objectr
    objectr Member
    May 28, 2014
    36
    I am running Android on my Udoo in combination with the 7" LVDS.
    The problem is that the left side of the lcd is not recognising any touch input. the active touch area ends 1cm before the actual lcd's end.
    sys/module/usbtouchscreen/parameters/calibration output is the following
    818,21,-1620131,12,481,-1100380,65536,800,480
    can someone confirm these values? or is there another way to adjust the touch-sensitve area?
    thanks!
  2. delba
    1,064
    Yes, it's a knows issue. We're working to fix it.
  3. Murazor
    Murazor New Member
    Jun 17, 2013
    I've the same issue...
    Waiting for the fix... :D :D :D :D
  4. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    I noticed the same. The biggest problem is that i couldn't trash icons from the dashboard cos i couldn't reach the "X" on the left.
    Anyway now i am using Nova Launcher that is much better than the stock launcher and i can remove icons too :D
  5. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Found something else about this.
    I needed to "touch" some buttons on the left side of the screen inside an app, so i plugged in a usb mouse and it worked as expected.
    Then I just found out a strange behavior: if you move the cursor all to the right or bottom side, it will be "squeezed".
    The same happens if you enable the option "show touches" under Developer Options and then you touch the screen on right and bottom. You'll see a squeezed glowing ellipse instead a circle.
    Maybe this can help you to find out what's wrong?
  6. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Just wondering... are we sure our 7" LVDS are not defective?
  7. Murazor
    Murazor New Member
    Jun 17, 2013
    Heeeeelloooooo....
    Any news about this problem? I'm thinking about an application for my car. And this issue is very annoying...
    I hope my 7"LVDS is not defective as fabio978 suppose...
  8. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Mine has been replaced... and it works now! So it's an hardware problem.
    Try opening a support ticket explaining the issue and i think they will send you a replacement.
  9. delba
    1,064
    Yep i suggest you to do what fabio978 did, open a ticket in our customer care section asking to replace the LVDS: http://www.udoo.org/customer-care/
  10. Murazor
    Murazor New Member
    Jun 17, 2013
    Yep....
    I'll do it just now...
    Thanks delba
