LVDS configuration
Discussion in 'SECOSBC-A62' started by stefanpini, Apr 20, 2016.
  1. stefanpini
    stefanpini New Member
    Feb 16, 2015
    14
    I'm trying to set up the LVDS display on the board A62 rev.B with UDOObuntu 2 (release SECOSBC-A62-QUAD).
    I'm using without success this bootargs configuration to start the display:
    setenv mmcargs setenv bootargs console=ttymxc1,115200 fbmem=10M video=mxcfb0:dev=ldb,1280x800M@60,if=RGB24,bpp=16
    The same LVDS display is working fine with this arguments on android 4.4.2:
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,1280x800M@60,if=RGB24,bpp=16 fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M
    Thanks in advance,
    Stefano
  2. stefanpini
    Feb 16, 2015
    14
    Is there anyone with a working LVDS?
  3. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Sorry, but i don't use udoobuntu with the seco (for the moment i'm working with neo and yocto ...). the lvds work fine with the ubuntu image give by seco.
    stefanpini likes this.
  4. stefanpini
    Feb 16, 2015
    14
    Thank you modjo!
    Which ubuntu did you try? Where can I find it?
    I'm using a display Ampire 1280800N3TZQW.
    I've tested the images from http://www.udoo.org/bsp-download-page/ :
    - uboobuntu2:
    setenv mmcargs setenv bootargs console=${console},${baudrate} root=${mmcroot} ${hdmi_patch} fbmem=24M video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=16
    setenv videomode mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=16
    setenv bootargs_base setenv bootargs ${console_interface} ${memory} ${cpu_freq} fbmem=24M ${videomode} ${root_dev}
    When I boot I see 4 penguins and after 1 second the screen is black with the backlight turned on.
    dmsg1.txt attached
    - android 5.0.2:
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,1280x800M@60,if=RGB24,bpp=16 video=mxcfb1:eek:ff video=mxcfb2:eek:ff fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M
    The screen is black and the backlight turned on.
    dmsg3.txt attached
    Any suggestion?
  5. wurstmann
    wurstmann New Member
    Mar 31, 2016
    i think u have to set the correct lvds display-timings in your devicetree
  6. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    you need to contact seco to have access to they ftp, perhaps @SECO_FAE can help more !
  7. Andrea Rovai
