LVDS pin outs to LCD screen pin outs
Discussion in 'General Discussion' started by rkwiles, Dec 18, 2013.
  1. rkwiles
    rkwiles New Member
    Sep 25, 2013
    Can someone help me out in matching these pins please.
    I have attached the LCD pin outs and UDOO LVDS pin out.
    I can figure out some of the connections but others i am have trouble with like for example does the pins 31 to 39 on the LCD need to be attached to UDOO board and if so were?
    Thank you for any help you can give me.
    edit: Did not see the attachments after submitting so pasted them here.
    LCD
    Pin Symbol      Description Notes
    1   NC                 No Connection.
    2   VCC               Power Supply, 3.3V Typ.
    3   VCC               Power Supply, 3.3V Typ.
    4   V EEDID        DDC 3.3V power
    5   NC                No Connection
    6   Clk EEDID    DDC Clock
    7   DATA EEDID  DDC Data
    8   RIN 0-      Negative LVDS differential data input
    9   RIN 0+      Positive LVDS differential data input
    10  GND         Ground
    11  RIN 1-      Negative LVDS differential data input
    12  RIN 1+      Positive LVDS differential data input
    13  GND         Ground
    14  RIN 2-      Negative LVDS differential data input
    15  RIN 2+      Positive LVDS differential data input
    16  GND         Ground
    17  CLKIN-      Negative LVDS differential clock input
    18  CLKIN+      Positive LVDS differential clock input
    19  GND         Ground
    20  RIN 3+      Negative LVDS differential data input
    21  RIN 3+      Positive LVDS differential data input
    22  GND         Ground
    23  VTSP        Power Supply, 3.3~5V (Typ.)
    24  VTSP        Power Supply, 3.3~5V (Typ.)
    25  GND         Ground
    26  I2C_CLK     I2C Clock for Touch
    27  I2C_Data    I2C Data for Touch
    28  Interrupt   MCU(Host) Alert
    29  Reset       Reset TSP
    30  XVDD_EN     XVDD Enable
    31  VCD6        LED Cathode
    32  VCD5        LED Cathode
    33  VCD4        LED Cathode
    34  VCD3        LED Cathode
    35  VCD2        LED Cathode
    36  VCD1        LED Cathode
    37  NC          No Connection
    38  VLED        Power Supply for LED (Anode)
    39  VLED        Power Supply for LED (Anode)
    Pin Symbol      Matching pin on LCD
    1   LVDS0_TX0_N
    2   LVDS0_TX0_P
    4   LVDS0_TX1_N
    5   LVDS0_TX1_P
    7   LVDS0_TX2_N
    8   LVDS0_TX2_P
    10  LVDS0_CLK_N
    11  LVDS0_CLK_P
    12  I2C3_SCL
    13  LVDS0_TX3_N
    14  LVDS0_TX3_P
    15  5V_LCD
    16
    17  3V3_LCD
    18  3P3V
    19  I2C3_SDA
    20  BL_ON
    21  VIN
    22
    23  TOUCH_INT
    24  TOUCH_RST
  2. rkwiles
    rkwiles New Member
    Sep 25, 2013
    So this can not be connected?
  3. Liu Yuezhong
    Liu Yuezhong New Member
    Jan 24, 2014
    Have u tried it out? I also want to know...
