Matlab/Labview?
Discussion in 'General Programming Discussion' started by hl68fx, Jan 23, 2014.
  1. hl68fx
    hl68fx New Member
    Jun 11, 2013
    24
    I would like to know if Udoo will get Matlab and Labview support?
    Kind regards
  2. mkopack
    mkopack Member
    451
    there's a few Open-source alternatives, some of which match Matlab language syntax. I'd suggest looking into those... Much more likely to find one of those that work at this stage than Matlab proper compiled to work on the Udoo...
  3. hl68fx
    hl68fx New Member
    Jun 11, 2013
    24
    thank you very much for your answer! :) My idea was to use Matlab Simulink and Labview to programm Udoo. Will this be possible in the near future? I found a Facebook comment where Udoo said that they are working on it.
  4. ram_tenet
    ram_tenet New Member
    Oct 22, 2013
    Just to get more insight .
    Are you trying to run matlab on the UDOO or do you want to run the generated code from Matlab to run on the Udoo both are different in their own case.
    I think the latter looks something that exits as a solution with some manual advanced manuevers but not the first one as Matlab has to be compiled for a ARM target
    --ram
  5. hl68fx
    hl68fx New Member
    Jun 11, 2013
    24
    Hi ram_tenet,
    I would like to run the generated code from Matlab and Labview on Udoo.
  6. gamemakerh
    gamemakerh New Member
    Jun 11, 2013
  7. ImIronman
    ImIronman New Member
    Mar 31, 2014
    Hey guys,
    I too wanna run a matlab program on udoo. Am quite new to this tech and I'm not quite aware of how do I compile the matlab code for an ARM processor. It would be great if anyone of u could throw some light upon it!
    Thank you!
  8. rpring9
    rpring9 New Member
    Jun 3, 2014
    Did you ever get an answer? I know that you can program an Arduino Due with Matlab but I can't seem to get matlab to recognize the Arduino after downloading the necessary support package.
  9. hl68fx
    hl68fx New Member
    Jun 11, 2013
    24
    I didn't get any answer and I had also no luck with the Matlab support package. There was a comment on facebook from the udoo-team that they are working on Matlab support but that was about a year ago... :(
  10. rpring9
    rpring9 New Member
    Jun 3, 2014
    Well, Matlab only recently came out with support for the Due. I believe it's only a problem with the board being recognized as "Silicon Labs CP210x USB to UART Bridge" instead of Arduino Due.
