MicroSD Specs needed for Udoo?
Discussion in 'UDOO 101' started by the1cyrus, Dec 23, 2013.
  1. the1cyrus
    the1cyrus New Member
    Nov 18, 2013
    14
    Can someone tell me what the udoo is compatible with when it comes to microSD?
    Will a 32gb microsd hc work?
    Is class 10 supported?
  2. venkatbo
    venkatbo Member
    45
    Yes, but presently, it can be formatted to use only 8GB.
    Yes, rather, it is recommended :)
  3. mkopack
    mkopack Member
    451
    Um, curious as to why you say it can only be done to 8GB?
    If you want to get a bigger card and use it all:
    Write the Udoo image of your choice to the card. At that point it will appear to only be an 8 GB partition. Boot, run parted (or gparted if you prefer a graphical interface, you might have to install it using apt-get install gparted)
    Use that to resize the partition, to use the rest of the card. Reboot. Should work fine.
