Mounting unchecked fs at boot
Discussion in 'Linux Ubuntu' started by stl, Feb 2, 2014.
  1. stl
    stl New Member
    Feb 2, 2014
    Hello there,
    I'm booting UDOO from a SSD. Everything else is mainly running smoothly but for some reason, at boot, ubuntu wont check /dev/sda1.
    What am I missing? Where is the script that decides to run fsck or not, can I make it more verbose? Or is this a u-boot issue?
    I'm getting the following at boot.
    [    3.058848] EXT2-fs (sda1): warning: mounting unchecked fs, running e2fsck is recommended
    [    3.067182] VFS: Mounted root (ext2 filesystem) on device 8:1.
    Fstab looks as follows.
    /dev/sda1 / ext2 errors=remount-ro 0 1
    /dev/sda2 none swap defaults
    /dev/sda3 /mnt/stuff ext3 defaults 0 2
    Tune2fs -l /dev/sda1
    tune2fs 1.42 (29-Nov-2011)
    Filesystem volume name:   <none>
    Last mounted on:          <not available>
    Filesystem UUID:          90f48a29-67eb-437f-9ac3-58603eb5655c
    Filesystem magic number:  0xEF53
    Filesystem revision #:    1 (dynamic)
    Filesystem features:      ext_attr resize_inode dir_index filetype sparse_super large_file
    Filesystem flags:         unsigned_directory_hash
    Default mount options:    user_xattr acl
    Filesystem state:         not clean with errors
    Errors behavior:          Remount read-only
    Filesystem OS type:       Linux
    Inode count:              1310720
    Block count:              5242880
    Reserved block count:     262144
    Free blocks:              3614198
    Free inodes:              1156192
    First block:              0
    Block size:               4096
    Fragment size:            4096
    Reserved GDT blocks:      1022
    Blocks per group:         32768
    Fragments per group:      32768
    Inodes per group:         8192
    Inode blocks per group:   512
    Filesystem created:       Sun Dec  8 14:23:53 2013
    Last mount time:          Sun Feb  2 15:18:48 2014
    Last write time:          Sun Feb  2 18:17:03 2014
    Mount count:              8
    Maximum mount count:      1
    Last checked:             Mon Jan 20 22:03:09 2014
    Check interval:           86400 (1 day)
    Next check after:         Tue Jan 21 22:03:09 2014
    Reserved blocks uid:      0 (user root)
    Reserved blocks gid:      0 (group root)
    First inode:              11
    Inode size:               256
    Required extra isize:     28
    Desired extra isize:      28
    Default directory hash:   half_md4
    Directory Hash Seed:      de4745bd-1474-41a4-a5b2-0122ac8b768c
    - stl
  2. miousername
    miousername New Member
    Jun 23, 2013
    73
    Hi Stl,
    The only way to check your sd card is to check it in an external pc because udoo don't use initramfs.
    If you create an initramfs with a very small set of library (busybox for example) you can check the sd filesystem.
    I hope this could be useful :geek:
