Multi-booting
Discussion in 'General Discussion' started by jandrew77, Dec 9, 2013.
  1. jandrew77
    jandrew77 New Member
    Dec 9, 2013
    With the increasing availability of ISO udoo, for example:
    Linaro Ubuntu 12.04 LTS
    Linaro Ubuntu 11.10
    Android 4.2.2 Jelly Bean
    Yocto
    Official XBMC release by Stephan Rafin
    Open Media Vault (NAS)
    anyone know the possibility of implementing a Multi-booting
    In which you can install more OS in the same SD and choose (via GUI) which OS to run at startup (with a bootable by default after a few seconds).
    ex. Programs for generate multi-booting Usb :
    xboot
    depot-multiboot
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Team UDOO have recently switched to uboot2013 which does support boot menus, but haven't implemented it (yet).
    However yes you can have multiple partitions on your Media (whether that be SD card or SATA, or both). You can interrupt the uboot boot process and then change the environmental variable to point to the partition which holds the OS you wish, then just tell it to continue booting. Not ideal, but a perfectly fine workaround for the moment.
    If Team UDOO don't do boot menu's then someone in the community will (which may then be adopted officially perhaps)
  3. delba
    1,064
    jandrew77 unfortunately we have no plan to implement a multi-booting system in a short time period (even though this would be a very nice features). Happy to see if one of our users will do that.
    As Lifeboat_Jim said you can interrupt the boot process and change the env variables. It's quite tedious but a working solution at the moment.
  4. the1cyrus
    the1cyrus New Member
    Nov 18, 2013
    14
    We need multi-boot asap!!!
