Multiple External Audio Interfaces
Discussion in 'Linux Ubuntu' started by romain, Jan 30, 2014.
  1. romain
    romain New Member
    Jan 30, 2014
    Hi Everyone,
    I'm trying to use two audio interfaces (Guitar Link UC6102) in parallel in Alsa on a UDOO board that runs Ubuntu. The two interfaces are connected on the two USB 2.0 port available on the board: I'm not using any hub. In 20% of the cases, this works fine and I'm able to use the two interfaces as one single "virtual" interface with 4 inputs and 4 outputs (see my .asoundrc file bellow). However, in 80% of the cases, this doesn't work and dmesg says: "cannot submit datapipe for urb 0, error -28: not enough bandwidth".
    So it seems that the problem comes from USB controller driver.
    I can use 4 of these interfaces on the same USB port with a hub on my Ubuntu laptop without any problem...
    Thanks for your help :)
    Cheers,
    Romain
    ps: your UDOO board really rocks!
    .asoundrc:
    pcm.myMAIN {
    type route;
    slave.pcm {
    type multi;
    slaves.a.pcm "myOUT0";
    slaves.b.pcm "myOUT1";
    slaves.a.channels 2;
    slaves.b.channels 2;
    bindings.0.slave a;
    bindings.0.channel 0;
    bindings.1.slave a;
    bindings.1.channel 1;
    bindings.2.slave b;
    bindings.2.channel 0;
    bindings.3.slave b;
    bindings.3.channel 1;
    ttable.0.0 1;
    ttable.1.1 1;
    ttable.2.2 1;
    ttable.3.3 1;
    #ttable.0.2 1; # front left
    #ttable.1.3 1; # front right
    #ttable.0.4 1; # copy front left to rear left
    #ttable.1.5 1; # copy front right to rear right
    ctl.myMAIN {
    type hw;
    card CODEC;
    pcm.builtIn {
    type hw
    card vt1613audio
    ctl.builtIn {
    type hw
    card vt1613audio
    pcm.myOUT0 {
    type hw
    card CODEC
    ctl.myOUT0 {
    type hw
    card CODEC
    pcm.myOUT1 {
    type hw
    card CODEC_1
    ctl.myOUT1 {
    type hw
    card CODEC_1
