Multiplexers & UDOO
Discussion in 'UDOO NEO' started by Maurice, Oct 14, 2016.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I have build a part of my project around my Arduino Mega, and I'm reconsidering to move it to my Neo. On my Mega I already use quite some pins, and I guess I'd be out of pins on the Neo quite quickly. Therefore I think of using a multiplexer.
    Having bad experiences with connecting a 4-digit display to the Neo because it uses a protocol where pins had to switch input or output mode[*] I'm wondering if a multiplexer like this would cause similar problems:
    http://tronixstuff.com/2013/08/05/part-review-74hc4067-16-channel-analog-multiplexerdemultiplexer/
    [​IMG]
    [*] UDOO has provided an update for the library some time ago. If it works I will switch.
  3. Maurice
    Oct 13, 2015
    394
    87
    @waltervl Never heard of PORTD until now, but what is the difference in ports?
  4. waltervl
    I edited my first post a little bit and added a link to arduino portmapping. I cannot recall a port mapping in the Neo Arduino sources. But perhaps I overlooked something.
  5. Maurice
    Oct 13, 2015
    394
    87
    Neo's package does state: Arduino Uno compatible... That doesn't end with simple read and writes to pins, does it?
  6. waltervl
  7. waltervl
    Andrea Rovai likes this.
  8. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Hi guys,
    about multiplexer on M4 side, can I do something like this?
    So through Serial.begin() and Serial.end() I can set different parameters (even if they have the same baudrate) and read two sensors on the same UART.
  9. waltervl
    My first impression it is not. Serial/uart cannot be multiplexed. Or you have to make some hardware switch that switches on command from one device to the other.
  10. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
