Hello all, I wanna control music player/audio out from Udoo trough any devic on local network. Web interface is the only option in order to avoid any additional app. Video is not needed, just mp3 and url streams. VLC would be the best option, however I am not able to keep it alive,VLC crash any time I open anything I have tried also other options..MPD,Rhythmbox,XBMC,Amarock...unfortunately no success. So I would like to kindly ask you,if you have any advice or recommendation for a solution which will run stable under Lubuntu 12.04 armHF please...do not hesitate to share! Any feedback is welcome! Thank you in advance. Regards Miro
vpeter: thanks for suggestion! Finally I found what I was looking for. I gotta LMS working. It is not compatible with armHF by default..so I will share "how to" for other UDOers. To install LMS follow this instruction: http://www.0x1.be/esa/dev/2014/02/01/ra ... boxserver/ To install squeezeslave there is many guides :ugeek: I am very happy to got it working, most important part of my smart home :mrgreen:
