Hi Guys what is the debug serial mark on the board? Am I supposed to solder an usb connector there (I doubt...) to get the debug? Or its pointing to some pins on J17? Thanks for explaining! Sent from my HTC One M8 using Tapatalk
Hello dear, there are two serials. One is on the micro usb port, but if you use Windows you gotta install the driver by yourself. On Linux it works out of the box The second serial is on the pins 46-47 of the connector J7. That one is a direct serial, so through that you access everything, uboot too.
