Neo I2C2 address 0x6F
Discussion in 'UDOO NEO' started by Gary Huband, Aug 30, 2016.
Tags:
  1. Gary Huband
    Gary Huband New Member
    Aug 1, 2016
    22
    When I run
    > sudo i2cdetect -y 1
    I see a device driver loaded at 0x6f. I would like to add a device that uses that address. Can I remove the current device? How?
    Thanks
  2. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    If there is a device at 0x6f then it should be declared in the dts files if a device driver is using it. If the device isn't in the dts files then the i2cdetect is finding a device on that address but no kernel device driver is loaded.
  3. waltervl
  4. Gary Huband
    Aug 1, 2016
    22
    I do not have a brick sensor connected. The 0x6F went away, so I must have made a mistake in my code running on the M4. I am curious though, why can I run i2cdetect on the A9 and see devices that are supposed to be connected to the M4?
  5. waltervl
    I don't know, only that I2C-2 is also the Arduino I2C bus.
    [​IMG]
  6. hiten
    hiten UDOOer
    Dec 9, 2019
    37
    "sudo i2cdetect -y 1" command not display anything if i connect my i2c sensor on I2c2(j5) why??
