OpenEmbedded/Yocto for UDOO Boards
Discussion in 'Yocto' started by graugans, Nov 7, 2015.
  1. addrazak
    addrazak New Member
    Apr 6, 2015
    @graugans: it's i7 cpu with 16 gb ram. I have a 32 Linux running and I thinking this is the problem as 32 bit OS will have limited address space. I will try removing qtwebengine first and then if it works I will reinstall my os.
    Sent from my iPhone using Tapatalk
  2. graugans
    Sep 17, 2015
    328
    141
    Okay, that's a good portion of ram. But maybe the 32bit os is the limit...
    addrazak likes this.
  3. addrazak
    addrazak New Member
    Apr 6, 2015
    @graugans : I removed qtwebengine references from local.conf and also from udoo-image-qt5.bb, I don't get that memory error. I will try with installing new OS after few days. Will play around with the target now.
    Thanks for your support and thanks to modjo
    modjo and graugans like this.
  4. graugans
    Sep 17, 2015
    328
    141
    Would be interesting if it works with 64bit OS...
  5. JonathanC
    JonathanC New Member
    Feb 25, 2016
    Hi graugans, I installed qt5 on UDOO Neo board but I can't launch remote debugging. In Debuggers options, I added arm-poky-linux-gnueabi-gdb but when I start debugging, the application stopped in the file dl-debug.c with a segmentation fault. I don't know what I could do for solving this problem, do you have any idea please ? Thanks for your help.
  6. graugans
    Sep 17, 2015
    328
    141
    For Qt5 related questions @modjo is the Pro.
    Can you please double check the configs and ensure, that you start QtCreator from the command line you've sourced the environment script from. And of course some screenshots and error messages will help to analyse the problems.
    JonathanC and modjo like this.
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    I'm agree with graugans, ensure you source the correct script (this will be a common error !), otherwise, post some screen shot of your Qt conf ? What is your version of qtcreator and qt lib on your host machine ... What image of qt5 have you build (the "base" image of meta udoo or the full with qtquickcontrols ...) ?
    JonathanC and graugans like this.
  8. JonathanC
    Feb 25, 2016
    Thanks @graugans and @modjo for your help.
    I checked my configs and did new tests and finally I realized that debugging worked for a simple application, so my configs seem correct.
    But when I try to debug my project which includes Qml and QQuickWidget, I have the following error :
    The inferior stopped because it received a signal from the operating system.
    Signal name : SIGILL
    Signal meaning : Illegal instruction
    I have build the qt5 "base" image without qtquickcontrols, this seems to be the problem.
    Now, I'm building the full qt5 image and I will inform you about the result.
    Thanks again for your work !
  9. graugans
    Sep 17, 2015
    328
    141
    JonathanC likes this.
  10. JonathanC
    Feb 25, 2016
    @graugans : Yes, I'll probably need to use the 7" screen.. Thanks for the patch, I will test it.
    graugans likes this.
  11. JonathanC
    Feb 25, 2016
    Unfortunately, the full qt5 image didn't fix the problem. When I run my project, it crashes with a segmentation fault and in remote debugging I get the error :
    Unable to find dynamic linker breakpoint function.
    GDB will be unable to debug shared library initializers
    and track explicitly loaded dynamic code.Could not load shared library symbols for 13 libraries, e.g. /usr/lib/libQt5QuickWidgets.so.5.
    Use the "info sharedlibrary" command to see the complete listing.
    Do you need "set solib-search-path" or "set sysroot"
    QQmlInspector: No plugin available for view ' QQuickWidget '
    But QQuickWidget is installed, I have the lib "libQt5QuickWidgets". I tried set sysroot with the lib path but it didn't work.
    I have Qt Creator 3.5.1 and Qt 5.5.1 installed on my host. Of course, the project can run on my host.
    @modjo you didn't have this problem with qml ? Did you try quickwidget ? Thanks for your help
  12. graugans
    Sep 17, 2015
    328
    141
    @JonathanC have you recreated the sdk after switching the image? And of course you have to reinstall the sdk.
    Is it possible to craft a simple example so I can debug the problems?
  13. JonathanC
    Feb 25, 2016
    @graugans : yes, I have recreated and resintalled the sdk.
    Here is the example Test.
  14. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    No i didn't have this problems, i will test your code this evening ...
  15. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @JonathanC i tried your example and have a segmentation Fault with QQuickWidget (your test and the exemple quickwidget) ! I have no problem with quickcontrols or other qml exemple ... I never use qml object with std widget (c++) in my app, i use directly QQmlApplicationEngine (or other quick view) to use qml and c++ for the algo ... This month (if i have the time i will make a little tutorial about this). For your problem, you can post a message on Qtforum or meta freescale (bug ...) and/or use directly a qml view (scene) in your app
  16. graugans
    Sep 17, 2015
    328
    141
    @modjo or @JonathanC can you post the call stack of the crash?
  17. JonathanC
    Feb 25, 2016
    @modjo I posted a message on Qtforum and freescale. I need QQuickWidget because I'm using c++ widgets for my project.
    I can't either use QWidget *container = QWidget::createWindowContainer(qmlView);
    I get the error EGLFS: OpenGL windows cannot be mixed with others
    @graugans There is no stack trace ..
    Thanks guys for your help
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Ok, the error EGLFS: OpenGL windows cannot be mixed with others is normal in EGLS platform because you can't have more 1 principal window in this mode ... Good luck for your problem and let us know if you find a solution !
  19. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @graugans I think i find a solution for 7" inch touch screen working with Qt but before to post the solution on git i launched a build from scratch (remove tmp, cache ...) and i remove tslib from my local.conf (i think not needed for us). But i have a problem with my build, i have this error and didn't find a solution :
    RROR: oe_runmake failed
    ERROR: Function failed: do_compile (log file is located at /media/modjo/data1TO/yocto/seco/udoo-community-bsp/neoBuild/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/crda/3.18-r0/temp/log.do_compile.32621)
    ERROR: Logfile of failure stored in: /media/modjo/data1TO/yocto/seco/udoo-community-bsp/neoBuild/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/crda/3.18-r0/temp/log.do_compile.32621
    Log data follows:
    | DEBUG: Executing shell function do_compile
    | NOTE: make -j 4 MAKEFLAGS= DESTDIR=/media/modjo/data1TO/yocto/seco/udoo-community-bsp/neoBuild/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/crda/3.18-r0/image LIBDIR=/usr/lib/crda LDLIBREG=-Wl,-rpath,/usr/lib/crda -lreg all_noverify
    |   GEN  keys-gcrypt.c
    |   Trusted pubkeys: pubkeys/linville.key.pub.pem pubkeys/sforshee.key.pub.pem
    | ERROR: Failed to import the "M2Crypto" module: /media/modjo/data1TO/yocto/seco/udoo-community-bsp/neoBuild/tmp/sysroots/x86_64-linux/usr/lib/python2.7/site-packages/M2Crypto/__m2crypto.so: undefined symbol: SSLv2_method
    | Please install the "M2Crypto" Python module.
    | On Debian GNU/Linux the package is called "python-m2crypto".
    | Makefile:113: recipe for target 'keys-gcrypt.c' failed
    | make: *** [keys-gcrypt.c] Error 1
    | WARNING: exit code 1 from a shell command.
    | ERROR: oe_runmake failed
    ERROR: Task 4633 (/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-openembedded/meta-networking/recipes-connectivity/crda/crda_3.18.bb, do_compile) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 2664 tasks of which 0 didn't need to be rerun and 1 failed.
    Waiting for 0 running tasks to finish:
    Summary: 1 task failed:
    Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
    Before to launch i bb, i make a repo sync and i have seen some update ... Do you have an idea to resolve this ?
  20. graugans
    Sep 17, 2015
    328
    141
    I'll check this later
