Yes, like @graugans said if you would to build an image for neo with CAN with Qt you need to switch to master Branch, to do that follow the step describe in wiki but replace this : git clone -b jethro https://github.com/meta-qt5/meta-qt5.git by git clone -b master https://github.com/meta-qt5/meta-qt5.git @graugans (master is preferable than jansa/master-5.6) By default meta-qt5 not build qtserialbus (needed for CAN), i have make a recipe (.bb) to build it like qtquickcontrols2 but it's preferable that i push a new request on git to that --> i think i can try this week end or next week ... this is my local.conf and my bblayers in local.conf just remove qtserialbus and qtquickcontrols2 for the moment ... Otherwise, can is not working with M4 together for the moment we ask @Francesco and @Andrea Rovai to help us on it, but i think they are busy on lolitop at the moment ... edit, this is my build config : Build Configuration: BB_VERSION = "1.28.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "Ubuntu-15.10" TARGET_SYS = "arm-poky-linux-gnueabi" MACHINE = "udooneo" DISTRO = "poky" DISTRO_VERSION = "2.0.1" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9" TARGET_FPU = "vfp-neon" meta meta-yocto = "master:1a52eceaa5df89914b6a711defdcf0046e74c7f6" meta-oe meta-multimedia meta-python meta-networking = "master:dc5634968b270dde250690609f0015f881db81f2" meta-fsl-arm = "master:8d22b44716fa624ff87383c36d222d9e28d0b267" meta-fsl-arm-extra = "master:2fdd1f7729c11900126f6c73346b8ea89448e927" meta-fsl-demos = "master:8bffde8d803dd2362fbded79781ce084d723b048" meta-qt5 = "master:d6fe20e6083d421cc6091892e1d302c46e2d075d" meta-ruby = "master:dc5634968b270dde250690609f0015f881db81f2" meta-udoo = "master:0ca56fc886b65776c2811b56de242bb2a628df01" NOTE: Preparing RunQueue NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks
I think the UDOO guys prepare the new kickstarter campaign I'll take a look into CAN after finishing some real life tasks Gesendet von meinem FP2 mit Tapatalk
Thank you for providing the above steps. This is my build config : Build Configuration: BB_VERSION = "1.29.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "Ubuntu-14.04" TARGET_SYS = "arm-poky-linux-gnueabi" MACHINE = "udooneo" DISTRO = "poky" DISTRO_VERSION = "2.0+snapshot-20160326" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9" TARGET_FPU = "hard" meta meta-yocto = "HEAD:5005cab723bc488bcf3f982a6401ecf49bdb9ca3" meta-oe meta-multimedia meta-python meta-networking meta-ruby = "HEAD:44f0e74954628d6a3d04fa5249dbe0c94f6dff59" meta-fsl-arm = "HEAD:9dd7dbc9f669637ade4bafa96bf74182c5c356ec" meta-fsl-arm-extra = "HEAD:de2eb544d854561c473b27ad3862a68ae965ef38" meta-udoo = "HEAD:1b38bcec5057b93017a00f107e0738ce64ade66f" meta-fsl-demos = "HEAD:6b779b2cb0d231063fc035a9a0871d722366c329" meta-qt5 = "master:d6fe20e6083d421cc6091892e1d302c46e2d075d" Now the question is how to build qtserialbus and qtquickcontrols2 since as you mentioned above to remove it for a movement. I want to build CAN can you tell me how shall i start.
WARNING: gst-plugins-good-0.10.31-r8 do_configure: QA Issue: gst-plugins-good: configure was passed unrecognised options: --disable-introspection [unknown-configure-option] ERROR: qtwebengine-5.5.99+5.6.0-rc+gitAUTOINC+3f02c25de4_779a2388fc-r0 do_configure: Function failed: do_configure (log file is located at /home/srijita/udoo-community-bsp/build/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/qtwebengine/5.5.99+5.6.0-rc+gitAUTOINC+3f02c25de4_779a2388fc-r0/temp/log.do_configure.15626) ERROR: Logfile of failure stored in: /home/srijita/udoo-community-bsp/build/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/qtwebengine/5.5.99+5.6.0-rc+gitAUTOINC+3f02c25de4_779a2388fc-r0/temp/log.do_configure.15626 Log data follows: | DEBUG: Executing python function sysroot_cleansstate | DEBUG: Python function sysroot_cleansstate finished | DEBUG: Executing shell function qmake5_base_preconfigure | DEBUG: Shell function qmake5_base_preconfigure finished | DEBUG: Executing shell function do_configure | ***Unknown option --disable-static | Usage: /home/srijita/udoo-community-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/qt5/qmake [mode] [options] [files] | | QMake has two modes, one mode for generating project files based on | some heuristics, and the other for generating makefiles. Normally you | shouldn't need to specify a mode, as makefile generation is the default | mode for qmake, but you may use this to test qmake on an existing project | | Mode: | -project Put qmake into project file generation mode | In this mode qmake interprets files as files to | be built, | defaults to *; *; *; *.ts; *.xlf; *.qrc | Note: The created .pro file probably will | need to be edited. For example add the QT variable to | specify what modules are required. | -makefile Put qmake into makefile generation mode (default) | In this mode qmake interprets files as project files to | be processed, if skipped qmake will try to find a project | file in your current working directory | | Warnings Options: | -Wnone Turn off all warnings; specific ones may be re-enabled by | later -W options | -Wall Turn on all warnings | -Wparser Turn on parser warnings | -Wlogic Turn on logic warnings (on by default) | -Wdeprecated Turn on deprecation warnings (on by default) | | Options: | * You can place any variable assignment in options and it will be * | * processed as if it was in [files]. These assignments will be parsed * | * before [files]. * | -o file Write output to file | -d Increase debug level | -t templ Overrides TEMPLATE as templ | -tp prefix Overrides TEMPLATE so that prefix is prefixed into the value | -help This help | -v Version information | -after All variable assignments after this will be | parsed after [files] | -norecursive Don't do a recursive search | -recursive Do a recursive search | -set <prop> <value> Set persistent property | -unset <prop> Unset persistent property | -query <prop> Query persistent property. Show all if <prop> is empty. | -cache file Use file as cache [makefile mode only] | -spec spec Use spec as QMAKESPEC [makefile mode only] | -nocache Don't use a cache file [makefile mode only] | -nodepend Don't generate dependencies [makefile mode only] | -nomoc Don't generate moc targets [makefile mode only] | -nopwd Don't look for files in pwd [project mode only] | WARNING: exit code 1 from a shell command. | ERROR: Function failed: do_configure (log file is located at /home/srijita/udoo-community-bsp/build/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/qtwebengine/5.5.99+5.6.0-rc+gitAUTOINC+3f02c25de4_779a2388fc-r0/temp/log.do_configure.15626) ERROR: Task 459 (/home/srijita/udoo-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb, do_configure) failed with exit code '1' NOTE: Tasks Summary: Attempted 3251 tasks of which 4 didn't need to be rerun and 1 failed. Waiting for 0 running tasks to finish: Summary: 1 task failed: /home/srijita/udoo-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb, do_configure Summary: There was 1 WARNING message shown. Summary: There was 1 ERROR message shown, returning a non-zero exit code. I am getting an error can anyone help me fixing this? I guss i have done some configuration wrong.
I guess you are not building meta-qt5 jansa/master-5.6 as recommended by me. This branch is needed unless this patch is merged into master. I recommend to get the basic Qt5 image up and running after this we can discuss how to fine tune it. After switching to jansa/master-5.6 deletion of build/tmp is recommended.
@Ayeed Shaikh , you are not on master branch on the other recipe (meta-fsl-arm ...) . Go to your sources folder (yocto git). After that go to each meta (meta-fsl-arm, meta-udoo ...) and in every source folder write in shell : $ git checkout master after this you will have the same config like me $ bitbake -c cleansstate udoo-image-qt5 $ bitbake udoo-image-qt5
Are you sure? meta-qt5 master still lacks this patch https://github.com/meta-qt5/meta-qt5/commit/bc54e237e5c8b31f056bf74c25404e4fb3155946 So either the jansa branch is recommended or master-next. But master next will be rebased so no good choice. Or I am completely wrong? Gesendet von meinem FP2 mit Tapatalk
Hi i compile on 2 PC meta qt5 with master branch and it's work fine (just a problem with qtwebengine and m2crypto) ...
Interesting, looks like something wiked happend to your branches: Code: $ cd poky $ git branch -r --contains 1a52eceaa5df89914b6a711defdcf0046e74c7f6 yocto/jethro $ cd ../meta-openembedded/ $ git branch -r --contains dc5634968b270dde250690609f0015f881db81f2 oe/jethro oe/jethro-next $ cd ../meta-fsl-arm $ git branch -r --contains 8d22b44716fa624ff87383c36d222d9e28d0b267 yocto/jethro yocto/jethro-next
my git : Code: modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources$ cd poky/ modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/poky$ git branch -r --contains m/jethro -> yocto/jethro yocto/jethro modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/poky$ cd ../meta-openembedded/ modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-openembedded$ git branch -r --contains m/jethro -> oe/jethro oe/jethro oe/jethro-next modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-openembedded$ cd ../meta-fsl-arm modjo@Linux-corei5:/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-fsl-arm$ git branch -r --contains m/jethro -> yocto/jethro yocto/jethro yocto/jethro-next
thank you graugans for the meta-udoo layer. im using it to build images for udoo-quad and seco-a62. but i can't use the eglfs plugin with the seco a62. ERROR MESSAGE: QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync. If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1 Could not open egl display Aborted it's working fine for udoo-quad. i'am using jethro-branch for each layer. does anyone got an idea what causes the problem? thx!
I have to check this. The Seco A62 is still work in progress I guess this is due to the fact A62 has multiple framebuffers. What kind of display are you using? Gesendet von meinem FP2 mit Tapatalk
this is my Build Configuration: BB_VERSION = "1.29.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "universal" TARGET_SYS = "arm-poky-linux-gnueabi" MACHINE = "udooneo" DISTRO = "poky" DISTRO_VERSION = "2.0+snapshot-20160401" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9" TARGET_FPU = "hard" meta meta-poky = "master:5005cab723bc488bcf3f982a6401ecf49bdb9ca3" meta-oe meta-multimedia meta-python meta-networking meta-ruby = "master:44f0e74954628d6a3d04fa5249dbe0c94f6dff59" meta-fsl-arm = "master:9dd7dbc9f669637ade4bafa96bf74182c5c356ec" meta-fsl-arm-extra = "master:de2eb544d854561c473b27ad3862a68ae965ef38" meta-udoo = "master:1b38bcec5057b93017a00f107e0738ce64ade66f" meta-fsl-demos = "master:6b779b2cb0d231063fc035a9a0871d722366c329" meta-qt5 = "master:d6fe20e6083d421cc6091892e1d302c46e2d075d" NOTE: Preparing RunQueue NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks WARNING: cinematicexperience-1.0-r0 do_fetch: Failed to fetch URL http://quitcoding.com/download/Qt5_CinematicExperience_rpi_1.0.tgz, attempting MIRRORS if available WARNING: imx-test-1_5.3-r0 do_fetch: Failed to fetch URL http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-test-5.3.tar.gz, attempting MIRRORS if available ERROR: imx-test-1_5.3-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 4, no output ERROR: imx-test-1_5.3-r0 do_fetch: Function failed: Fetcher failure for URL: 'http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-test-5.3.tar.gz'. Unable to fetch URL from any source. ERROR: Logfile of failure stored in: /home/srijita/udoo-community-bsp/build/tmp/work/udooneo-poky-linux-gnueabi/imx-test/1_5.3-r0/temp/log.do_fetch.21061 ERROR: Task 3440 (/home/srijita/udoo-community-bsp/sources/meta-fsl-arm/recipes-bsp/imx-test/imx-test_5.3.bb, do_fetch) failed with exit code '1' Waiting for 4 running tasks to finish: 0: lttng-ust-2_2.7.1+gitAUTOINC+f89c1a3cf2-r0 do_fetch (pid 16541) 1: qt3d-native-5.5.99+5.6.0-rc+gitAUTOINC+9b9f34701f-r0 do_fetch (pid 27485) 2: cinematicexperience-1.0-r0 do_fetch (pid 27664) 3: qtconnectivity-5.5.99+5.6.0-rc+gitAUTOINC+dec32076b9-r0 do_fetch (pid 27684) is my build config but iam unable to use meta-oe meta-multimedia meta-python meta-networking what to do?
I recommend to switch meta-qt5 to jansa/master-5.6 Go to meta-qt5 folder and call Code: git checkout -b master-5.6 origin/jansa/master-5.6
Can anyone provide me a working complied image for neo lvds7 that runs CAN and qt5 with sensors please I am stuck with compilation.
.git srijita@srijita:~/master/sources$ git checkout -b master-5.6 origin/jansa/master-5.6 fatal: Not a git repository (or any of the parent directories): .git
