OpenEmbedded/Yocto for UDOO Boards
Discussion in 'Yocto' started by graugans, Nov 7, 2015.
  1. graugans
    Sep 17, 2015
    328
    141
    you have to go to meta-qt5 directory
  2. graugans
    Sep 17, 2015
    328
    141
    I'll build one tomorrow
  3. graugans
    Sep 17, 2015
    328
    141
    Ayeed Shaikh and modjo like this.
  4. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    will it run on udoo neo? does it have support for qt5 application development?
  5. graugans
    Sep 17, 2015
    328
    141
    No, it is for Quad and Dual and is a GUI image some other guy asked for. I have finished the qt5 build but there are issues with CAN what I want to fix before uploading
  6. graugans
    Sep 17, 2015
    328
    141
  7. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @graugans , in your qt5.6 image did you add qtserialbus ?
  8. graugans
    Sep 17, 2015
    328
    141
    Not, yet. Could you be so kind and send me the recipe?
  9. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
  10. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    How to change the default hdmi to lvds7 i tried uEnv video_output =lvds7 but still its booting with hdmi
  11. graugans
    Sep 17, 2015
    328
    141
    This, should work. How did you edit the file? Looks like u-boot is a bit picky when it comes to line endings.
  12. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    No problem, see here for qtserialbus and qtquickcontrols2
    graugans likes this.
  13. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    # Environment script for the UDOO Neo board
    # save this file with unix-like newlines! (\n, 0x0A)
    #save this file with unix-like newlines! (\n, 0x0A)
    video_output=lvds7
    m4_enabled=true
    # Select weather to use custom device tree or not
    # Put the custom device tree file in the folder "dts-overlay" in your boot partition
    # use_custom_dtb=true|false
    # any other value (or if the variable is not specified) will default to "false"
    #use_custom_dtb=true
  14. graugans
    Sep 17, 2015
    328
    141
    Sorry for being imprecise, how did you modify the file. What Operating system and what Editor?
  15. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    I used gedit using ubuntu 14.0
  16. graugans
    Sep 17, 2015
    328
    141
    Thx, I will test this this afternoon. Ubuntu is fine Windows maybe problematic.
  17. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    # Enable or Disable the Cortex M4 CPU
    # m4_enabled=true|false
    # any other value (or if the variable is not specified) will default to "true"
    #m4_enabled=false
    # Set the screen connected to the board
    # video_output=hdmi|lvds7|lvds15|disabled
    # any other value (or if the variable is not specified) will default to "hdmi"
    #video_output=hdmi
    This was your uEnv.txt i changed video_output=lvds7.
  18. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    Ok no issues and thanks for providing me the image. I actually want it to boot with lvds7 and not with hdmi.
  19. graugans
    Sep 17, 2015
    328
    141
    Can you verify what device tree is loaded by hooking up a USB <-> UART 3.3V TTL adapter. I described it here
    When I set the
    video_output=lvds
    The u-boot output looks like this:
    reading uEnv.txt
    702 bytes read in 12 ms (56.6 KiB/s)
    Running bootscript from mmc ...
    Device Tree: imx6sx-udoo-neo-full-lvds7-m4.dtb
    ** File not found /var/opt/m4/m4last.fw **
    reading /m4startup.fw
    108208 bytes read in 23 ms (4.5 MiB/s)
    ## Starting auxiliary core at 0x84000000 ...
    reading /zImage
    4131152 bytes read in 206 ms (19.1 MiB/s)
    Booting from mmc ...
    reading imx6sx-udoo-neo-full-lvds7-m4.dtb
    45748 bytes read in 42 ms (1 MiB/s)
    Kernel image @ 0x80800000 [ 0x000000 - 0x3f0950 ]
    ## Flattened Device Tree blob at 83000000
       Booting using the fdt blob at 0x83000000
       Using Device Tree in place at 83000000, end 8300e2b3
    Switched to ldo_bypass mode!
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 3.14.56_1.0.x-udoo+gabdce68 (chris@quadros) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Sun Apr 3 20:41:51 CEST 2016
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine model: UDOO Neo Full
    [    0.000000] Reserved memory: reserved region for node 'm4@0x84000000': base 0x84000000, size 8 MiB
    [    0.000000] Reserved memory: reserved region for node 'm4@0xBFF00000': base 0xbff00000, size 1 MiB
    [    0.000000] cma: CMA: reserved 320 MiB at aa000000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] PERCPU: Embedded 8 pages/cpu @bf639000 s8256 r8192 d16320 u32768
    [    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait rw ${mmcrootfstype} uart_from_osc clk_ignore_unused cpuidle.off=1 consoleblank=0
    The following line indicates the LVDS 7" Display is used:
    I can not test the LVDS 7" Display because I do not own one by myself. But @modjo may can help. And there is some guidance on the UDOO docs
  20. graugans
    Sep 17, 2015
    328
    141
