Back from the beach. You may have to enable the pure-ftp server and add an bbappend for its configuration. I would recommend to use ssh instead Gesendet von meinem FP2 mit Tapatalk
Due to the fact I still have no lvds it's hard to test. But remember a62 has different logic to select lvds Gesendet von meinem FP2 mit Tapatalk
@graugans I accidentally ran into this post and perhaps it needs an update as Udoo now supports Arduino IDE 1.6.9
Even though I had previously successfully created the image for the udoo board following your tutorial. I recently had to install linux mint because ubuntu started crashing a lot and giving me lots of problems and when trying to create the image again I get the following errors: Code: ERROR: u-boot-udooboard-git-r0 do_fetch: Fetcher failure: Unable to find revision d7814685bdb364a4162f5bb4431676631591fc38 in branch 2015.04.imx-neo even from upstream ERROR: u-boot-udooboard-git-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://github.com/udooboard/uboot-imx.git;branch=2015.04.imx-neo'. Unable to fetch URL from any source. ERROR: Logfile of failure stored in: /home/m4l490n/udoo-community-bsp/build/tmp/work/udooneo-poky-linux-gnueabi/u-boot-udooboard/git-r0/temp/log.do_fetch.11074 ERROR: Task 160 (/home/m4l490n/udoo-community-bsp/sources/meta-udoo/recipes-bsp/u-boot/u-boot-udooboard_git.bb, do_fetch) failed with exit code '1' Do you know why this is happening? Thanks!!
This is because the udoo guys removed the branch and reorganised the u-boot git. That's annoying, because of this I have to fix all old branches.... Gesendet von meinem FP2 mit Tapatalk
I would like to but I don't know how to redact it. Can I just put whatever I told you in my post above?
That's perfect. I already pushed a fix yesterday. But was not able to test. Gesendet von meinem FP2 mit Tapatalk
thanks for the fix but i think its not working. i tried to compile it and following error appears: http://pastebin.com/raw/iG25kDcY u-boot is looking for arch/../configs/udoo_qdl_defconfig but there is only a "udoo_qd_defconfig" file.
Ah, thx for pointing this out. I just checked for the Neo. I renamed the Quad/Dual according to the previous name. I'll check and update the patchset
@graugans , @wurstmann today i have build a new image of yocto from scratch to my seco A62 quad. I use krogoth branch of your layer graugans. It compile fine with qt5.6.1 ! (just an error with qquickcontrols2 but i think it's a metaqt5 issue ...) . After that i burned the image on a sd card and insert it in the card. It startup fine with hdmi and now qt5cinematic experience work great (60 fps) --> lsmod give me galcore now ! Thanks for your job After that i remove the sd card to configure it to use lvds7, to did that i edited uEnv.txt : video_output=lvds7 # 7" LVDS Panel video=fbmem=24M video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666,bpp=32 Then i rebooted the card. I can saw on the lvds7 screen the bootScreen (udoo image) with the progress bar, but after that nothing --> the screen becomes white ! I can connect it with ssh. Do you have an idea what i'm doing wrong and/or how to resolve this please ?
Hello, I try to build an image with your recipes but I cannot run bitbake. I get this error: Code: $ MACHINE=udooneo bitbake udoo-image-full-cmdline WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution. ERROR: OE-core's config sanity checker detected a potential misconfiguration. Either fix the cause of this error or at your own risk disable the checker (see sanity.conf). Following is the list of potential problems / advisories: Failed to create a file with a long name in TMPDIR. Please use a filesystem that does not unreasonably limit filename length. Failed to create a file with a long name in SSTATE_DIR. Please use a filesystem that does not unreasonably limit filename length. This error makes no sense as I run it on an ext4 partition which allows 255 characters. Any idea? Thanks in advance!
Perfect thanks! That worked for a while and then I got this error: It means that the filenames are longer than 255 characters which is the maximum a filesystem can allow today. That makes the build impossible.
What is the filename it is stumbling upon? Is it really > 255 characters? Perhaps you have something similar as http://stackoverflow.com/questions/...rrno-36-file-name-too-long-for-filename-short
