@modjo can you please copy all m4* firmware files from UDOOBuntu to the Boot partition of the yocto SD-Card and retest USB issues? It looks like a m4 firmware is needed for a powered USB. @Andrea Rovai is this true?
This is ok, now i have usb on neo ! I have made an image for udoo quad that seems to work (usb, eth ok, Qt5 ok) Could you re-precise the procedure to make the tool-chain sdk please ?
THX for the feedback. I'll write some advice about the toolchain later... Gesendet von meinem Nexus 4 mit Tapatalk
i have a problem since your update, if i try a repo sync, i have this errors now : modjo@Linux-corei5:/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/seco/udoo-community-bsp/neoBuild$ repo sync Fetching project meta-udoo Fetching project Documentation Fetching project meta-fsl-demos Fetching project meta-openembedded Fetching projects: 12% (1/8) Fetching project meta-fsl-arm Fetching projects: 25% (2/8) Fetching project meta-fsl-arm-extra Fetching projects: 37% (3/8) Fetching project poky Fetching projects: 50% (4/8) Fetching project fsl-community-bsp-base Fetching projects: 100% (8/8), done. error: Your local changes to the following files would be overwritten by checkout: recipes-udoo/images/udoo-image-qt5.bb Please, commit your changes or stash them before you can switch branches. Aborting error: sources/meta-udoo/: meta-udoo checkout d89cb80aad5486e0c43222083e2191449dc53eea
Can you please change to meta-udoo folder and call git diff And post the result here or on github's gist service? Gesendet von meinem Nexus 4 mit Tapatalk
I can not see any special, you can do the following in the meta-uddo folder: $ git stash This should fix your issues
very nice wok !!! you are an incredible man guy ! About the qt creator conf, i make a test yesterday (with my old neo config) and have a problem to compil with the sdk. Do you test a deploy on the card (since your host machine) , tomorrow i will make a test !
You need to source the toolchain before starting qtcreator. From cmdline otherwise compilation fails. Deployment from creator not yet tested. Gesendet von meinem Nexus 4 mit Tapatalk
Hi graugans, good news the build for neo and quad is ok and deploy with qtcreator on the card work fine !!! Good job ! Just little points to update : The path to the poky sdk for me is /opt/poky/2.0.1/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi some module are missing like qtquick controls, qt3d canvas ... i will try to add it and let you know. Gpu accelerated (under eglfs) seems good. Otherwise, i let active wayland for the build ... About the kernel, i have a egalax touch screen (usb) that works under udoobuntu2 but not with yocto. Do you build a special kernel ?
Thx, for the update. I guess they updated the upstream Jethro branch to 2.01 this is the cause for the 2.01. I'll fix this. Regarding the kernel I do use the same configs. Can you please provide output of - lsmod - dmesg Before and after plugin of the touch? Gesendet von meinem Nexus 4 mit Tapatalk
BTW you may have to add the arm gdb to qtcreator like you did for the g++ for remote debugging. Gesendet von meinem Nexus 4 mit Tapatalk
Yes, i forgot gdb ... otherwise, i had some missing module and it seems to compile ... For the touch screen, i can say this tomorrow (i erase my sd and i'm waiting the new build ). A question, i add new module to qt5 image, i need to rebuild the sdk, but do i need to remove the directory /opt/poky or the sdk script will update it ?
Normally by adding modules you do not need to wipe your build directory. When installing a new toolchain I erase the old before. Because it is a simple shell script. Gesendet von meinem Nexus 4 mit Tapatalk
Graugan, this is my udoo-image-qt5 : https://gist.github.com/modjo756/15d82766d957df7a2022 This work, but when i add to it qtwebengine \ qtwebengine-qmlplugin \ The layer is find and fetched, but during the compile i have this error : https://gist.github.com/modjo756/e649d7473fd618c3a5ba Do you have an idea ? edit : perhaps i find a solution, ligne 39 of the log, there is this error : /udoo-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtwebengine/5.5.1+gitAUTOINC+qtwebengine_146ebe26dc-r0/git/src/3rdparty/chromium/ui/gfx/codec/jpeg_codec.cc:123:10: error: invalid conversion from 'int' to 'boolean' [-fpermissive] and i find this : https://github.com/meta-qt5/meta-qt5/commit/d8b2426588abd64c079b8796b7fb3ff68fc2351e Do i need to apply this patch manually ? If yes how ?
for the Patch: go to meta-qt5 $ cd recipes-qt/qt5/qtwebengine_git.bb download all the patches from the commit https://github.com/meta-qt5/meta-qt5/commit/d8b2426588abd64c079b8796b7fb3ff68fc2351e by view -> raw $ wget https://raw.githubusercontent.com/m....cc_Change-false-to-FALSE-and-1-to-TRUE.patch fix the bb file Code: + file://0002-media_capture_devices_dispatcher.h-Include-QCoreApplication-translate.patch \ + file://0003-WebEngine-qquickwebengineview_p_p.h-add-inc-QColor.patch \ + file://0001-chromium-jpeg_codec.cc_Change-false-to-FALSE-and-1-to-TRUE.patch \ " " Or you have to create a bbappend in the meta-udoo Or wait until I've fixed it for you in meta-udoo
