Ok, i use the patch like you say (don't use your update), and it work, just this warning : WARNING: QA Issue: ELF binary '/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/seco/udoo-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtwebengine/5.5.1+gitAUTOINC+qtwebengine_146ebe26dc-r0/packages-split/qtwebengine-plugins/usr/lib/qt5/plugins/qtwebengine/libffmpegsumo.so' has relocations in .text [textrel] WARNING: QA Issue: qtwebengine rdepends on qtlocation, but it isn't a build dependency? [build-deps] NOTE: Tasks Summary: Attempted 4776 tasks of which 4760 didn't need to be rerun and all succeeded.
UPDATE 27.01.2016 ROOTFS Partion is expanded to SD-Card size during first boot The very last one should be fixed by my update. Code: WARNING: QA Issue: qtwebengine rdepends on qtlocation, but it isn't a build dependency? [build-deps] The first one will be hopefully fixed with my next update
for lsmod : https://gist.github.com/modjo756/739ae77f32bae86f1256 dmesg : [ 8895.075031] usb 1-1.2: USB disconnect, device number 3 [ 8897.873413] usb 1-1.2: new full-speed USB device number 6 using ci_hdrc [ 8898.005275] usb 1-1.2: New USB device found, idVendor=0eef, idProduct=0001 [ 8898.012199] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 8898.019669] usb 1-1.2: Product: USB TouchController [ 8898.024662] usb 1-1.2: Manufacturer: eGalax Inc.
About your update, i apply $ repo sync $ MACHINE=udooqdl bitbake udoo-image-qt5 I have this error : ERROR: Command Error: exit status: 1 Output: Patch 0002-media_capture_devices_dispatcher.h-Include-QCoreApplication-translate.patch is already applied; check your series file ERROR: Function failed: patch_do_patch ERROR: Logfile of failure stored in: /media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/seco/udoo-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtwebengine/5.5.1+gitAUTOINC+qtwebengine_146ebe26dc-r0/temp/log.do_patch.26004 ERROR: Task 449 (/media/modjo/39a50e93-4c35-4598-a6b8-9627986411e5/yocto/seco/udoo-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb, do_patch) failed with exit code '1' Do i need to make a clean of qtwebengine to resolve this ? Otherwise, i have added some modules to qt5 but one module give me some issue. I would to add qtquickcontrols-qmlplugin to udoo-image-qt5.bb --> my file https://gist.github.com/modjo756/23bf84e4e3ae5feb73e6 it fetch qtquickcontrol but i have this error during do_rootfs https://gist.github.com/modjo756/0584836fa56545c01da3 In meta qt5 we can find this package https://github.com/meta-qt5/meta-qt5/blob/master/recipes-qt/packagegroups/packagegroup-qt5-toolchain-target.bb but i can't find a solution to use it (perhaps i need another module to build it ...)
Regarding the build error of qtwebengine this is caused by your modification either in the original recipe or by adding a second bbappend so you have to revert this first. Otherwise the buildsystem tries to apply patches a second time this will not work Gesendet von meinem Nexus 4 mit Tapatalk
Or you can do a git checkout -- qtwebengine.bb in the meta-qt5 when changed there. Gesendet von meinem Nexus 4 mit Tapatalk
Ok build with success with your layer, but already this error about qtquickcontrols I didn't find any solution ... Otherwise qtquick (particles, video effect ...) works very good on quad i will make some video about this but before i would like to build qtquickcontrols !!! edit : perhaps, they have another modules to install, but i'm not an expert with yocto, see this post https://community.freescale.com/docs/DOC-100419
Have you tried to create an issue on the meta-qt5 repo on github regarding the qtquickcontrols issue. Frankly this is beyond my limited QtGui knowledge Maybe you have to enable them in a recipe or they are part of another package. Do you have an idea how the files are named?
I will try to post an issue on meta qt5 repo, nice idea ! I already post a mail on the meta freescale mailing list but no answer for the moment ... Other point, qt multimedia can't read video for the moment (no service provider)--> need to install gstreamer dev tool (i will try it). Otherwise, do you know how to enable the power button on udoo quad ?
I can not find your post on meta-fsl Mailinglist. Just one mail regarding X11 and Qt. Gesendet von meinem Nexus 4 mit Tapatalk
i poste my mail on this mail list --> meta-freescale@yoctoproject.org yesterday. Under a copy of my mail : Hi, i have an issue to build qtquickcontrols-qmlplugin with qt5.5.1 (jethro branch). I'm doing this for a udoo board (neo and quad) with this meta :https://github.com/graugans/meta-udoo. I added the meta qt5 layer and i can deploy some app to the board (cinematic experience work fine in eglfs). The problem is that i didn't have qt quick control, when i add it to the image, it fetch but i have this error during do_rootfs :ERROR: qtquickcontrols-qmlplugins not found in the base feeds (complete error here : https://gist.github.com/modjo756/0584836fa56545c01da3) this is the bb for qt5 image that i use : https://gist.github.com/modjo756/23bf84e4e3ae5feb73e6 i didn't find a solution for the moment thank's in advance for your help !
@modjo you need to activate accessibility to provide qtquickcontrols Related to this posting on the ML you need to tweak your local.conf like this And then add add qtdeclarative-qmlplugins qtquickcontrols-qmlplugin Or like Otavio suggested in this post To the image. I recommend to do this by an extra udoo-image-qt5.bbappend file Code: IMAGE_INSTALL += " \ qtdeclarative-qmlplugins \ qtquickcontrols-qmlplugins \ " Otherwise you'll always run in trouble when I do updates on the image file.
I think i can say thanks for the community ! Graugans, with your tip about quickcontrol, it's ok ! build fine and lib install in rootfs and sdcard resize work fine at boot, good job ! (another time) But i have a last point (to have a full qt install in your bsp !!!), for the moment we can't play video with qt. Gstreamer 1 is install, but in usr/lib/qt5/plugins/mediaservice/ we just have libqtmedia_audioengine.so (on the sdcard). But to have the full multimedia pack (video, cam ...) we need to add : - libgstmediacapture.so - libgstcamerabin.so - libgstmediaplayer.so - libgstaudiodecoder.so See this post : http://forums.wandboard.org/viewtopic.php?f=10&t=1057 i have added this to your udoo-image-qt5.bb GSTREAMER_TOOLS = " \ packagegroup-fsl-gstreamer1.0-full \ gstreamer \ gst-plugins-base-app \ gst-plugins-base \ gst-plugins-good \ gst-plugins-good-rtsp \ gst-plugins-good-udp \ gst-plugins-good-rtpmanager \ gst-plugins-good-rtp \ gst-plugins-good-video4linux2 \ " make a : $ MACHINE=udooqdl bitbake -ccleanall qtmultimedia $ MACHINE=udooqdl bitbake udoo-image-qt5 But it's not sufficient, i don't have the lib ! do you have an idea about this ? for information, the error is : defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer" edit : I'm trying with this option : PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010"
I'll take a look into gstreamer soon. I guess 0.10 is not the way to go. But maybe I am wrong. What package config did you finally used the first one or the one from Otavio? Gesendet von meinem Nexus 4 mit Tapatalk
