OpenEmbedded/Yocto for UDOO Boards
Discussion in 'Yocto' started by graugans, Nov 7, 2015.
  1. graugans
    Sep 17, 2015
    328
    141
    Are you on Neo or Quad/Dual?
    Gesendet von meinem Nexus 4 mit Tapatalk
  2. graugans
    Sep 17, 2015
    328
    141
    Do you have any error message?
  3. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    yes, arduino ide can't establish connexion ! perhaps they need to add FOTA to the image ? Otherwise, i have seen that if i program (blink exemple) the M4 with udoobuntu2 (with a pc) and after that launch the card with yocto image the led is not blinking !
  4. graugans
    Sep 17, 2015
    328
    141
  5. graugans
    Sep 17, 2015
    328
    141
    modjo likes this.
  6. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    yes, this will be the solution !;)
    graugans likes this.
  7. graugans
    Sep 17, 2015
    328
    141
    I just pushed two recipes for udoofota and m4uploader. The udoofota needs some fine tuning related to starting the server during boot-up (init.d).
    All of this is mostly untested...
    modjo likes this.
  8. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    bb in working ...
    for info, when i start a bitbake, i have this warning
    WARNING: Getting checksum for qtwebengine SRC_URI entry 0002-media_capture_devices_dispatcher.h-Include-QCoreApplication-translate.patch: file not found except in DL_DIR | ETA: 00:01:02
    WARNING: Getting checksum for qtwebengine SRC_URI entry 0003-WebEngine-qquickwebengineview_p_p.h-add-inc-QColor.patch: file not found except in DL_DIR
    WARNING: Getting checksum for qtwebengine SRC_URI entry 0001-chromium-jpeg_codec.cc_Change-false-to-FALSE-and-1-to-TRUE.patch: file not found except in DL_DIR
  9. graugans
    Sep 17, 2015
    328
    141
    Further investigation on the QA warnings needed...
  10. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Compilation works without error, good job. The (neo) card boot but i think the M4 is not started and impossible for the moment to upload with arduino. Like you said need to tune udoofota ! perhaps udooteam can help
  11. graugans
    Sep 17, 2015
    328
    141
  12. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Great ! Do i need to recompil yocto or can i write it directly on the sd (/boot i presume ?)
  13. graugans
    Sep 17, 2015
    328
    141
    So meta-udoo should be ready for M4 FOTA ....
  14. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    repo sync
    bb
    copie to sd
    All seems ok, i will test tomorrow !
  15. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi graugans, the A9 boot but it seems that the M4 doesn't ! I have enabled it in Uenv.text but it stay halt ! If i plug the sd with udoobuntu2 the M4 start and the led blink (i have loaded a blink exemple, leg toggle each second), but if i plug sd with yocto the led stay off.
  16. graugans
    Sep 17, 2015
    328
    141
    Okay, I'll check this M4 is a long standing topic on my list.
    modjo likes this.
  17. graugans
    Sep 17, 2015
    328
    141
    @modjo argh, I love it fixing stuff totally unrelated to the topic I want to fix... I am not a fanboy of Arduino but this drove me crazy..... I finally fixed Arduino GUI, by manually changing the target IP in the file
    ~/.arduino15/packages/UDOO/hardware/solox/1.6.5/platform.txt
    Is this the way to go or did I missed the menu item to change stuff @Andrea Rovai ?
    Anyway the real bug I was hunting was a missing directory: /var/opt/m4/
    So everything should be fine after an update.
    modjo likes this.
  18. Andrea Rovai
    At the moment we didn't made available any tool to change the IP from GUI. The correct mode is, how you said, modifying the file
    /home/chris/.arduino15/packages/UDOO/hardware/solox/1.6.5/platform.txt
    Would you be able to write a guide for this? It would be SUPERCOOL. We haven't released a guide yet because this stuff could eventually cause security problems.
    modjo and graugans like this.
  19. graugans
    Sep 17, 2015
    328
    141
    [UDOO Neo] Arduino workflow on Yocto for M4 core
    Follow the instruction how to install the Arduino GUI on the UDOO Neo Docs
    Install and configure the Arduino IDE
    • Download Arduino Software in version 1.6.5 for your Platform Arduino_dl_version.png
    • Install the Arduino IDE on your PC
    • Start the IDE. Select File -> Preferences and add this link to Additional Boards Manager URLs: https://udooboard.github.io/arduino-board-package/package_udoo_index.json , then click Ok.
    • Select Tools -> Boards and open the Board Manager.
    • Wait few seconds 'till the end of the "index download" then look for UDOO NEO (iMX6 SoloX) and install it.
    • After this a new board is selectable in Tools -> Boards you should see the UDOO NEO (Cortex M4), if so Click on it.
    • Now it's time to insert your first sketch
      void setup(){
          pinMode(13, OUTPUT);
      void loop(){
          delay(1000);
          digitalWrite(13, LOW);
          delay(1000);
          digitalWrite(13, HIGH);
    • Compile it but not yet upload it
    • For uploading the binary to the M4 we are using the Firmware over the Air Update Feature (FOTA) to get this working you have to edit the following file:
      and scroll down to the line
      tools.udooclient.upload.pattern="{path}/{cmd}" "192.168.23.147:5152" "{build.path}/{build.project_name}.bin"
      and adapt the IP address to your needs. This is the one the Neo port was assigned to.
      Thx for @modjo pointing out the location for this file under windows:
      C:\Users\<YOUR_USER>\AppData\Roaming\Arduino15\packages\UDOO\hardware\solox\1.6.5
    modjo likes this.
  20. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Another time thanks for this ;) I will try tomorrow and let you know !
