@modjo, are using windows for Arduino? If yes can you please post the windows path? Gesendet von meinem Nexus 4 mit Tapatalk
Hi graugans, very goog job, the M4 works now just a point to verify-> your script create the folder /var/opt/M4 but i need to put manually the file m4last.fw (tested 2 times, erase and dd sdcard) afeer that it works very well. Tested with arduino ide under win7 and linux ! the path for windows is : Code: C:\Users\YOUR_USER\AppData\Roaming\Arduino15\packages\UDOO\hardware\solox\1.6.5
@modjo I will test this, with a fresh install. Can you please be so kind and add all your outstanding issues as issues in github? So I can track them better. BTW it would be cool to get some stars in github
No problem, i will do this in future ... let me know if it's that you want https://github.com/graugans/meta-udoo/issues/3
After a little test, lvds7 inchs work, just need to add some adjustment (see git issues). About Qt, touch not working for the moment (with lvds7). Serial com between M4 and A9 works ... I will begin a little tutorial with qt now ...
Hi, i would like to enable espci2 (A9 side) that is disabled for the moment : from imx6sx-udoo-neo-externalpins.dtsi in : udoo-community-bsp/neoBuild/tmp/work/udooneo-poky-linux-gnueabi/linux-udooboard/3.14.56-r0/git/arch/arm/boot/dts/ &ecspi2 { fsl,spi-num-chipselects = <1>; cs-gpios = <&gpio6 14 0>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi2>; status = "disabled"; }; I suppose i have just to write status = enabled but how i can recompile kernel from yocto ?
Unless I manage to write some docs you can read this https://www.yoctoproject.org/sites/default/files/kernel-lab-1.6.pdf Gesendet von meinem Nexus 4 mit Tapatalk
@graugans/modjo Thank you for the excellent guide. I started from scratch by installing ubuntu 14.04 and by following you tutorial it worked fine until i started to cross compile the QT5 SDK. I am getting the below error: Did you guys face such issue?? | /home/abdul/build/tmp/sysroots/i686-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot find -lQt5XmlPatterns | ERROR: oe_runmake failed | ERROR: Function failed: do_compile (log file is located at /home/abdul/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtdeclarative/5.5.1+gitAUTOINC+3e9f61f305-r0/temp/log.do_compile.13876) ERROR: Task 241 (/home/abdul/sources/meta-qt5/recipes-qt/qt5/qtdeclarative_git.bb, do_compile) failed with exit code '1' NOTE: Tasks Summary: Attempted 4108 tasks of which 3801 didn't need to be rerun and 1 failed. Waiting for 0 running tasks to finish: Summary: 1 task failed: /home/abdul/sources/meta-qt5/recipes-qt/qt5/qtdeclarative_git.bb, do_compile Summary: There were 8 ERROR messages shown, returning a non-zero exit code.
@addrazak what platform are you building for? Neo or Quad/Dual? I had similar issues when building first for Neo and afterwards for the Quad. It was a while ago when I did a complete Qt5 build. I can try this afternoon to build a fresh Qt5 image.
Hi, i didn't remember to have this issue but my local.conf (and bblayers) are different from the git --> i had some modules to have a full qt5 image ! I can post this evening my conf ...
@graugans: I am using udoo quad. I was thinking about this and wondering if I would first have to install QT natively on my Ubuntu 14.04? Did you guys have this installed on your system before building the tool chain? I ask this because the recipe seems to be looking for some libraries that are missing Sent from my iPhone using Tapatalk
@modjo: I used the conf files you provided, but this time it fails while building the image itself. Below is the error. Did you face this issue? | linking ../../lib/libQt5WebEngineCore.so.5.5.1 | /home/abdul/udoo-community-bsp/build/tmp/sysroots/i686-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: fatal error: libQt5WebEngineCore.so.5.5.1: mmap: failed to allocate 1559168904 bytes for output file: Cannot ERROR: oe_runmake failed | ERROR: Function failed: do_compile (log file is located at /home/abdul/udoo-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtwebengine/5.5.1+gitAUTOINC+qtwebengine_146ebe26dc-r0/temp/log.do_compile.29312) ERROR: Task 7 (/home/abdul/udoo-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb, do_compile) failed with exit code '1' NOTE: Tasks Summary: Attempted 1709 tasks of which 1703 didn't need to be rerun and 1 failed. No currently running tasks (1709 of 1716) Summary: 1 task failed: /home/abdul/udoo-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb, do_compile Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Hi i didn't remember to have this error, normally now they have all the patch to build qtwebengine ! did you make a bitbake -c cleanall udoo-image-qt5.bb before your build ? Sometimes when i have too many errors i make a big clean of my yocto package (tmp folder ...) and restart a build ! Perhaps you can try to build the image for the moment without qtwebengine (and add it after), to do this remove qtwebengine \ qtwebengine-qmlplugins \ from local.conf
