https://www.lazada.com.my/pqi-pb-12...9013586.html?spm=a2o4k.search.0.0.ntbPQj&ff=1 https://www.lazada.com.my/original-...6906616.html?spm=a2o4k.search.0.0.tJJzIq&ff=1 https://www.lazada.com.my/eaget-pt9...4134534.html?spm=a2o4k.search.0.0.PK6aOE&ff=1 The above are the only 3 laptop powerbanks available in my country, x86 specified 12v input but did not specify the Amp, the power adapter read 12v 3000mA, one of the above power bank stated 2A for 12V, is that good enough ? Also thinking of hooking a logitech webcam and 6" touch screen onto x86, which also get power from x86, is this possible?
As you stated the supplied power supply is 3A. I have my board (Advanced) running with nothing attached and I think its closer to 1.5A under load.
None of the power banks you specified have an 12V+/-5% output (as input for the X86). Mostly laptops are charged with much higher voltages, 15-19V. So yo cannot use these unless you regulate the output down with a voltage regulator.
