Printable template for mounting holes x86
Discussion in 'UDOO X86' started by Paul Pentecost, May 5, 2017.
  1. Paul Pentecost
    Paul Pentecost New Member
    Apr 26, 2017
    Is there or does someone have a template that I can print out to scale that I can stick to something and drill out holes to mount my udoo x86? I don't want to have to use my board itself as the template and risk using a drill near it etc.
    paul.
  3. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    You should be able to use the main board or the bottom of the standard case and safely mark the hole positions with a pencil. You will also likely need M3 spacers and screws to provide clearance for the main board and M.2 components.
  4. eastsidebuzz
    eastsidebuzz New Member
    Jan 15, 2018
    Anyone have a template for the holes needed for a face plate on a case?
