Problem Downloading Ubuntu1204 V2.0 - Too Large
Discussion in 'UDOO 101' started by playinmyblues2, Dec 14, 2013.
  1. playinmyblues2
    playinmyblues2 New Member
    Dec 14, 2013
    My UDOO Quad came the other day and I had already downloaded Ubuntu from Mirror EU and the SorceForge sites. Both versions resulted in a requirement of about 700 PB to unzip. The first file I opened originally showed normal file size but later showed the excessive size.
    I got the file on the third try from the SorceForge site. Anybody else have these problems?
  2. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Use 7zip or another 3rd party utility to unzip it. It's just the way the filesize is described and not really that size.
    This is covered in the getting started document, tutorials and on this forum.
  3. playinmyblues2
    Dec 14, 2013
    Hi. Thanks for the tip. I was using the default unzip that comes with Windows. Once I downloaded it on Linux and unzipped it it worked well. I just unzipped it using 7zip with no problems.
    If you are a moderator, it would be a good tip to place in that information in the "Creating a bootable Micro SD card" tutorial found here: http://www.udoo.org/getting-started/cre ... rom-image/
  4. playinmyblues2
    Dec 14, 2013
    And yes, I just saw you are a moderator. Thanks for the help. :)
