Problem installing Arduino IDE HFP
Discussion in 'Linux Ubuntu' started by hl68fx, Feb 2, 2014.
  1. hl68fx
    hl68fx New Member
    Jun 11, 2013
    24
    I have tried to install the new Arduino IDE HFP Version on Ubuntu 12.04 (Udoo Quad) because I hope that the I2C problem has been solved.
    I followed this tutorial: http://www.udoo.org/install-the-arduino-ide-hfp/
    I had to put "sudo" in front of every command, without it did not work.
    After the last command (./arduino-1.5.4/arduino) I get the following error:
    bash: ./arduino-1.5.4/arduino: No such file or directory
    I really appreciate your help!
  2. delba
    1,064
    Maybe you don't have Arduino installed in that specific directory. You need to check where you untar the package.
  3. Capstan
    Capstan New Member
    Feb 14, 2014
    18
    I think you are encountering the same problem I saw and posted about here;
    viewtopic.php?f=17&t=1021
    We seem to be trying to execute code that requires hardware floating point, and apparently what we have is software floating point. I don't know if that's merely an issue with the Linux build we are using or the Udoo hardware implementation. I advise going through the same steps but this time install the SFP version of Java. We also must run the SFP version of Arduino IDE.
    What is "the I2C problem"?
  4. Capstan
    Capstan New Member
    Feb 14, 2014
    18
    Also see this post;
    viewtopic.php?f=15&t=996
    "we didn't release the HF version of Ubuntu 12.04, only Debian & Ubuntu Studio. Try with Debian armHF"
