Hi all, i'm trying to configure a ftp server on my udoo (under udoobuntu) but i have somes problems. i installed gadmin-proftpd, configure it with a anonymous and personal account but when i'm trying to connect it with filezilla (or a file manager) i obatain this errors : Code: Status: Connecting to 192.168.1.30:21... Status: Connection established, waiting for welcome message... Response: 220 camFtp Command: USER anonymous Response: 331 Anonymous login ok, send your complete email address as your password Command: PASS ************** Response: 230 Anonymous access granted, restrictions apply Command: OPTS UTF8 ON Response: 200 UTF8 set to on Status: Connected Status: Retrieving directory listing... Command: PWD Response: 257 "/" is the current directory Command: TYPE I Response: 200 Type set to I Command: PASV Response: 227 Entering Passive Mode (192,168,1,30,223,183). Command: MLSD Error: Connection closed by server Error: Failed to retrieve directory listing I already tried to configure filezilla in active or passive mode ... but nothing works ! Before that i already test this configuration on another PC (uder ubuntu 14) and it works fine, do you have an idea about this problem ?
yes, i have the same port on my file ! Do you use proftp with success on your card ? Perhap's you don't use gadmin to configure it ? For information, for the moment i just test ftp on local network, they just have a switch between my pc and udoo. Filezilla works on udoo to upload an another server (my pc for exemple) by impossible to configure in the other side (pc to udoo).
I didn't tried ftp server with udoobuntu, sorry... Actually, I use pure-ftpd when I need to configure a ftpd, maybe give it a try.
