Problem with I2C devices
Discussion in 'UDOO NEO' started by alvamabel2018, Apr 20, 2018.
  1. alvamabel2018
    alvamabel2018 New Member
    Apr 20, 2018
    I managed to properly connect to the temperature sensor, through the brick snap in port. I see the device on I2C bus 1 with address 0x48 and I can read its register without problems.
    I would like to connect another I2C device (IMU MPU9265), do I have to export GPIOs in order to connect it to one of the 4 I2C buses? Or I just need to wire the Vcc pin to the 5V or 3V3 pin on Neo, the GND pin to one of the GND pin on Neo, and SCL/SDA to pins SCL/SDA of the internal row on Neo?
    I did just that and I can't see the device appear on any of the four buses with i2cdetect. Connecting it to those pins I should see it on I2C2, i.e. with i2cdetect -y 1, right?
    As long as the I2C sensors dont use the same I2C adress you can connect them to the same I2C bus. No need to use the other busses.
    Be aware:
    1. All I2C busses are exported to A9/Linux side. So no need to do anything with GPIO.
    2. I2C_2=i2c-1 in linux (and I2C_4=i2c-3)
    [​IMG]
