I'm trying to run a Processing (3.0.1 for ARMv6hf) sketch on my UDOO Neo from an SSH terminal and having all kinds of problems. udooer(~)||$ processing-3.0.1/processing-java --sketch=path/to/sketch --run Listening for transport dt_socket at address: 8553 Could not parse -1 for --display # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x62989694, pid=1691, tid=1506255968 # # JRE version: Java(TM) SE Runtime Environment (8.0_51-b07) (build 1.8.0_51-b07) # Java VM: Java HotSpot(TM) Client VM (25.51-b07 mixed mode linux-arm ) # Problematic frame: # C [libGL.so.1+0x36694] glGetString+0xc # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /home/udooer/hs_err_pid1691.log # # If you would like to submit a bug report, please visit: # http://bugreport.java.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Finished. Could not run the sketch (Target VM failed to initialize). For more information, read revisions.txt and Help → Troubleshooting. Could not run the sketch. udooer(~)||$ glxinfo | head -n 30 name of display: localhost:10.0 display: localhost:10 screen: 0 direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose) server glx vendor string: SGI server glx version string: 1.4 server glx extensions: GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: Vivante Corp client glx version string: 1.4 client glx extensions: GLX_ARB_get_proc_address, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_make_current_read GLX version: 1.4 GLX extensions: GLX_SGIX_fbconfig OpenGL vendor string: Intel Inc. OpenGL renderer string: Intel HD Graphics 5000 OpenGL Engine OpenGL version string: 1.4 (2.1 INTEL-10.6.33) OpenGL extensions: udooer(~)||$ java -version java version "1.7.0_91" OpenJDK Runtime Environment (IcedTea 2.6.3) (7u91-2.6.3-0ubuntu0.14.04.1) OpenJDK Zero VM (build 24.91-b01, mixed mode) I've tried installing different JDKs and OpenGL drivers, but I don't really know what I'm doing and haven't figured out the right combo of packages to get this to work. It also could be that I just _can't_ run processing sketches over SSH, which would be obnoxious but non-fatal, since I intend on running the sketch via upstart anyway. Any suggestions? Sorry in advance if this has been thoroughly covered elsewhere.
