Purpose of the third usb cable?
Discussion in 'General Discussion' started by jayfehr, Dec 22, 2013.
  1. jayfehr
    jayfehr New Member
    Oct 26, 2013
    13
    I just received my starter kit cables, and among them was the third usb cable that connects just behind the two micro usb ports. I'm curious what the purpose of this cable/port is? The other two are for programming remotely, how/why would I use this one? There may be some interesting applications that I am not yet aware of.
  2. maurizio
    maurizio Administrator
    Jul 1, 2013
    35
    It is a standard USB, you can use this if you need more USB ports or connect some USB devices inside a case/box containing UDOO
  3. Robandstuff
    Robandstuff New Member
    Jan 11, 2014
    Related question: could I connect a powered USB hub to the internal usb connector, and then grab 5v power from the J23 bank to power the hub (assuming I am using a sufficiently large power supply - say 12v/5amp)?
    This would then allow you to chain a theoretically large number of devices to the Udoo. Say 4 HDDs (obviously there's a limit on max throughput when adding more devices to the same USB port, but still useful for scenarios where large storage space is more important than speed)?
