PWM export: Permission denied
Discussion in 'UDOO NEO' started by Andres Rodriguez, Feb 20, 2016.
  1. Andres Rodriguez
    Andres Rodriguez New Member
    Dec 28, 2015
    Hi, I'm trying to use the PWM from an application in python and I am following documentation to enable it http://www.udoo.org/docs-neo/Hardware_&_Accessories/PWM.html. The Step 1 I've done, but when export it in step 2, I do not have permissions. Thanks for the help.
    echo 0 > /sys/class/pwm/pwmchip0/export
    -bash: /sys/class/pwm/pwmchip0/export: Permission denied
    sudo echo 0 > /sys/class/pwm/pwmchip0/export
    and if you use
    sudo sh -c "echo 0 > /sys/class/pwm/pwmchip0/export"
    If this works it looks like you have to do the same extra actions as for the other GPIO pins: GPIO through /sys/class but then for sys/class/pwm also
    Andres Rodriguez likes this.
  3. Andres Rodriguez
    Dec 28, 2015
    Hi @waltervl, thanks for your help this was the solution, it was a matter of adding the rule. Thanks
    Andrea Rovai likes this.
