Hi I'm having an issue communicating with the UDOO Dual from Windows. I am able to upload a sketch via the IDE on Windows using a port that shows up as 'COM3'. However, the below code triggers a port error (I've commented out the linux portion of the code). Code: import time import serial import threading #port = serial.Serial('/dev/ttyS1', 115200) port = serial.Serial('COM3', 115200)
So the issue, it turns out, was that the Arduino IDE must be closed in order to access the same serial connection (on a Windows system). The above code should work at opening a connection if you get pyserial installed correctly.
