Qt and qtquickcontrols.extras - solved
Discussion in 'Yocto' started by Retasor, Nov 16, 2017.
  1. Retasor
    Retasor New Member
    Dec 26, 2016
    11
    I have build an Yocto image for the SECOSBC-A62 with Qt support. I build the image following @graugans instructions built used the latest version of the meta-qt.
    The image works fine and qt is working. But I can't get the Qt Quick Extras working. This is the qt package where the extra controls are located like the CircularGauge. When I try to use this in my package it is complaining that Qt Quick Extras is missing. It seems part of the qtquickcontrols and that one I have included in the udoo-image-qt.bb under the QT_TOOLS sections
        qtquick1 \
        qtquick1-plugins \
        qtquick1-qmlplugins \
        qtquickcontrols \
        qtquickcontrols-qmlplugins \
        qtquickcontrols2 \
        qtquickcontrols2-qmlplugins \
    I can't find the Quick.Extras in generated SDK or on the target so somehow it is not build but I can't figure out how I can add this. So I hope somebody can tell me how I can add this part of the QtQuick system.
  2. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    @Retasor, i have the same problem has you with quickExtras (part of quickControls) probably a dependency missing ... Did you find a solution ?
    I found this on web but didn't help me for the moment ...
  3. Retasor
    Retasor New Member
    Dec 26, 2016
    11
    @modjo Yes I solved it after a lot of searching and trying. But forget to update this post so thank you for the sweet reminder ;-)
    The QtQuickControls.Extra which contains the circular gauge has a dependency on the Qt Accessibility feature. I simple added it to my local.conf file:
    ## Accessibility is required to compile qtquickcontrols
    PACKAGECONFIG_append_pn-qtbase = " accessibility"
    modjo likes this.
