Resolution monitor lvds
Discussion in 'Linux Ubuntu' started by larosa.cristian, Oct 31, 2014.
  1. larosa.cristian
    larosa.cristian New Member
    May 15, 2014
    17
    Hi, I'm larosa cristian, I am writing after viewing the forum and did not find what I need. I have attached a screen of 10.3 "and a 15" on the door of my udoo lvds quad, the problem is as follows, with 10 "inches using the" udoo configuration tool "makes me set as 7" inch, however, the colors and the markings are well defined, however, you can see the desktop one and a half, the 15 "inch instead configure it as a 15" but it looks bad because the menu icon to turn off even seen going out of the screen, which file should change in order to accommodate the resolutions.
    Thanks in advance
    Regards
  2. delba
    1,064
    I believe our customer care (ticketing system) already took care of your issue. Am i right?
  3. larosa.cristian
    May 15, 2014
    17
    I solved it, I wrote here because I had not received a response from the first ticket system
  4. delba
    1,064
  5. J.C.
    J.C. New Member
    Oct 24, 2016
    I have a similar issue. I have been able to change the resolution for an LVDS display through xrandr. Unfortunately, I have not been able to set this up as a standard screen that is recognized at startup. The xrandr commands are listed below. I would like to have a default dts file to load for this display. I am running the full udoobuntu 2.1 image on an Udoo dual.
    xrandr --newmode "1280x768_60.00" 80.14 1280 1344 1480 1680 768 769 772 795 –HSync +VSync
    xrandr --addmode 0x3f 1280x768_60.00
    xrandr --output 0x3f --mode 1280x768_60.00
    Thanks,
    J.C.
